Revision as of 14:13, 27 July 2026 by SFZ (Talk | contribs)
Tool Length/Offsets G43Hn G49
Note All the projects should work out-of-the-box with Visual Studio 2022.
Linux Support
See here for more info.
KFLOP specific Hardware Info
KStep specific Hardware Info
Touch Plate Wiring to Konnect
3D Board Models
KonnectHoles.stp.txt
Kanalog.stp.txt
Roberto Gotti of Powertech)
KANALOG_BOARD.stp.txt
SnapAmp.stp.txt
2 Snap Amps added to Curtis's KFLOP STEP model - Thanks to Isaac
KFlop_2SnapAmp.stp.txt
Board Terminal DXF/DWG files
Jogging Pendant
Basic Servo Tuning Overview
I Gain/Max Limit Integrator
  2. D Gain of 35
  4. Servo Sample Time of 90us
Spanish
