- 3.1 Installation Topics
- 3.3 Configuration Topics
- 3.5 PC Example Applications
- 3.7 Kinematics
- 3.8 KFLOP C Programs
- 3.9 ModBus
- 3.10 Linux Support
- 5.9 Max Limits - Error
- 5.12 Bode Plots
- Announcement of our Latest Release (5.3.3) on the Dynomotion Forum
- Previous Test Release: 02/01/2024: KMotion.exe 5.3.2, See the release notes for this test version here: 5.3.2 release notes (pdf)
- Previous Test Release: 11/20/2023: KMotion.exe 5.3.1, See the release notes for this test version here: 5.3.1 release notes (pdf)
Individual Axes can be corrected in a 1 dimensional manner referred to as Linear Table Corrections. For more information See here.
Linux Support
See here for more info.
KFLOP specific Hardware Info
KStep specific Hardware Info
3D Board Models
Roberto Gotti of Powertech)
Board Terminal DXF/DWG files
KFLOP_Terminals.dxf KFLOP_Terminals.dwg
Kanalog_Terminals.dxf Kanalog_Terminals.dwg
Konnect_Terminals.dxf Konnect_Terminals.dwg
KStep_Terminals.dxf KStep_Terminals.dwg
Cables that connect between Dynomotion boards are normally included when purchasing the boards together. They are also very common and easy to make.Use 16-conductor or 26-conductor ribbon cable (0.05 inch pitch 26 AWG preferrably or 28AWG) and IDC sockets.
Also AMP Series MATE-N-LOK P# 1-480424-0 using AMP Series MATE-N-LOK Crimp Pins P# 60619-1 or P# 194200002
Molex Crimp Tool P# 0640160035
