- 5.7 Bode Plots
Table of contents:
- Introduction
- Control styles
- Control attributes
- Main Window attributes
- Show/Hide Controls
- Change Label/Button Text
- Change Font/Text Size
- Bitmap Buttons and Labels
- JPG, BMP, PNG Bitmaps
- Toggle Bitmap Labels (LEDs)
- Custom User Entry Controls
- Label
- Momentary button
- DualLabel
- Select ID
- Show/Hide
- Move/Resize
- Main Dialog Screen
- Script File
