Updating KFLOP Firmware
Revision as of 18:01, 27 June 2018 by TK (Talk | contribs)
The error:
indicates that the PC Version of the software that you have
installed doesn't match the firmware software that has been flashed internally into KFLOP.  To update the firmware in KFLOP to match the version of software you are using perform the following steps:
  1. Run KMotion.exe
