Changes
/* 3D Board Models added SnapAmp Step files */
===Installation Topics===
* Announcement of our Latest Release (5.04.71) on the [https://www.dynomotion.com/forum/viewtopic.php?f=4&pt=6459 1884 Dynomotion Forum]
* Previous Test Release: 06/03/2025: [https://dynomotion.com/Software/KMotion5.4.0.exe KMotion.exe 5.4.0], See the release notes for this test version here: [https://dynomotion.com/Software/KMotion%20Released%20Version%205.4.0%20Changes.pdf 5.4.0 release notes (pdf)]
* Previous Test Release: 04/08/2025: [https://dynomotion.com/Software/KMotion5.3.8.exe KMotion.exe 5.3.8], See the release notes for this test version here: [https://dynomotion.com/Software/KMotion%20Released%20Version%205.3.8%20Changes.pdf 5.3.8 release notes (pdf)]
* Previous Test Release: 01/14/2025: [https://dynomotion.com/Software/KMotion5.3.7.exe KMotion.exe 5.3.7], See the release notes for this test version here: [https://dynomotion.com/Software/KMotion%20Released%20Version%205.3.7%20Changes.pdf 5.3.7 release notes (pdf)]
* Previous Test Release: 09/30/2024: [https://dynomotion.com/Software/KMotion5.3.6.exe KMotion.exe 5.3.6], See the release notes for this test version here: [https://dynomotion.com/Software/KMotion%20Released%20Version%205.3.6%20Changes.pdf 5.3.6 release notes (pdf)]
* Previous Test Release: 09/16/2024: [https://dynomotion.com/Software/KMotion5.3.5.exe KMotion.exe 5.3.5], See the release notes for this test version here: [https://dynomotion.com/Software/KMotion%20Released%20Version%205.3.5%20Changes.pdf 5.3.5 release notes (pdf)]
* Previous Test Release: 08/13/2024: [https://dynomotion.com/Software/KMotion5.3.4.exe KMotion.exe 5.3.4], See the release notes for this test version here: [https://dynomotion.com/Software/KMotion%20Released%20Version%205.3.4%20Changes.pdf 5.3.4 release notes (pdf)]
* Previous Test Release: 04/04/2024: [https://dynomotion.com/Software/KMotion5.3.3.exe KMotion.exe 5.3.3], See the release notes for this test version here: [https://dynomotion.com/Software/KMotion%20Released%20Version%205.3.3%20Changes.pdf 5.3.3 release notes (pdf)]
* Previous Test Release: 02/01/2024: [https://dynomotion.com/Software/KMotion5.3.2.exe KMotion.exe 5.3.2], See the release notes for this test version here: [https://dynomotion.com/Software/KMotion%20Released%20Version%205.3.2%20Changes.pdf 5.3.2 release notes (pdf)]
* Previous Test Release: 11/20/2023: [https://dynomotion.com/Software/KMotion5.3.1.exe KMotion.exe 5.3.1], See the release notes for this test version here: [https://dynomotion.com/Software/KMotion%20Released%20Version%205.3.1%20Changes.pdf 5.3.1 release notes (pdf)]
* Previous Test Release: 09/19/2023: [https://dynomotion.com/Software/KMotion5.3.0.exe KMotion.exe 5.3.0], See the release notes for this test version here: [https://dynomotion.com/Software/KMotion%20Released%20Version%205.3.0%20Changes.pdf 5.3.0 release notes (pdf)]
* Previous Test Release: 06/30/2023: [https://dynomotion.com/Software/KMotion5.1.0.exe KMotion.exe 5.1.0], See the release notes for this test version here: [https://dynomotion.com/Software/KMotion%20Released%20Version%205.1.0%20Changes.pdf 5.1.0 release notes (pdf)]
* Previous Test Release: 05/01/2023: [https://dynomotion.com/Software/KMotion5.0.7.exe KMotion.exe 5.0.7], See the release notes for this test version here: [https://dynomotion.com/Software/KMotion%20Released%20Version%205.0.7%20Changes.pdf 5.0.7 release notes (pdf)]
* Previous Test Release: 09/21/2022: [https://dynomotion.com/Software/KMotion435h.exe KMotion.exe V4.35h], See the release notes for this test version here: [https://dynomotion.com/Software/KMotion%20Released%20Version%204.35h%20Changes.pdf V4.35h release notes (pdf)]
* Previous Version 4.35g was not released, but see the change notes for this version here: [https://dynomotion.com/Software/KMotion%20Released%20Version%204.35g%20Changes.pdf V4.35g change notes (pdf)]
Note the Geometric Correction is built into the KMotion Libraries and can be utilized by Custom Programs as well as with KMotionCNC<br />[[Geometric Correction|More information and Examples.]]
Individual Axes can be corrected in a 1 dimensional manner referred to as Linear Table Corrections. For more information See [[Linear Table Correction|here]].
===PC Example Applications===
'''Note All the projects in KMotion Versions 4.34a and later have now been updated and should work out-of-the-box with VS2015Visual Studio 2022.'''
===Wiring Diagrams===
[[File:SnapAmp_Step.png|none|link====KFLOP IDC Connectors and Cables====Cables that connect between Dynomotion boards are normally included when purchasing the boards together. They are also very common and easy to make. <br /><br />Use '''16-conductor or 26-conductor ribbon cable''' (0.05 inch pitch 26 AWG preferrably or 28AWG) and IDC sockets.<br /><br />]]
[[Media:KFlop_2SnapAmp.stp.txt|2 Snap Amps added to Curtis'''IDC Sockets 26s KFLOP STEP model -pin '''(pin pitch 0.1 inch)'''<br />'''Thanks to Isaac]]
[[Media:KFLOP_Terminals.dxf|KFLOP_Terminals.dxf]] [[Media:KFLOP_Terminals.dwg|KFLOP_Terminals.dwg]]
[[Media:Kanalog_Terminals.dxf|Kanalog_Terminals.dxf]] [[Media:Kanalog_Terminals.dwg|Kanalog_Terminals.dwg]]
[[Media:Konnect_Terminals.dxf|Konnect_Terminals.dxf]] [[Media:Konnect_Terminals.dwg|Konnect_Terminals.dwg]]
[[Media:KStep_Terminals.dxf|KStep_Terminals.dxf]] [[Media:KStep_Terminals.dwg|KStep_Terminals.dwg]]
===Wiring Topics===
Molex Series 8981 P# [https://www.digikey.com/short/zjp329 0015244048] using Molex Series 8980 Crimp Pins P# [https://www.digikey.com/short/zjp3ff 0002081201]
Also AMP Series MATE-N-LOK P# [https://www.digikey.com/short/zjpq3n 1-480424-0] using AMP Series MATE-N-LOK Crimp Pins P# [https://www.digikey.com/short/zjpqqw 60619-1] or P# [https://www.digikey.com/en/products/detail/molex/0194200002/2404783 194200002] Molex Crimp Tool P# [https://www.digikey.com/en/products/detail/molex/0640160035/665311 0640160035]
==Applications and Projects==
:* Place links to pages that explain how you accomplished your particular project. Write clear explanations that provide background on what you did and how you did it.
====[[Tool Changer - router linear 4 Tools - C Program]]====[[File:LINEAT+ATC.jpg|none|link=|246x178px]]====More linear milling tools: https://www.ichome.com/
====[[Driving Hobby Servos]]====
