A number of PC Applications using the KMotion Libraries are available in the Software download. Visual Studio should be used to modify/compile the applications. Currently the projects are compatible with VS 2022. In some cases MFC (Microsoft Foundation Classes) capability needs to be added as a separate download.
Link to the Microsoft Free Visual Studio Community Versions
Note the App being debugged should be using the Debug Versions of the KMotion Libraries from the Debug folder rather than the Release folder. The BuildAllLibs.sln in configuration Debug may be used to create the Debug Versions.
Quote:
KMotionDLL.dll
KMotion_dotNet.dll
KMotion_dotNet_Interop.dll
GCodeInterpreter.dll
KMotionServer.exe
TCC67.exe
