Revision as of 16:37, 23 May 2026 by TK (Talk | contribs)
  • Show/Hide Controls
  • Change Label/Button Text
  • Change Font/Text Size
  • Bitmap Buttons and Labels
  • JPG, BMP, PNG Bitmaps
  • Toggle Bitmap Labels (LEDs)
  • Custom User Entry Controls
Combo Box Control with Drop Down Lists in KMotion CNC Screen Editor
https://www.youtube.com/watch?v=Pp5DPfn8GLI
Dual Button Types in KMotion CNC Screen Editor
https://youtu.be/w-bKvqXCd0Q
https://youtu.be/VkBhYpyGpNU
Main Screen Style
https://youtu.be/R44F0_upIoA
  • Label
  • Button
  • MotionButton
  • ToggleButton
  • DROLabel
  • VertBar
  • Radio button
  • Momentary button
  • DualButton
  • Checkbox
  • DualLabel
  • Select ID
  • Type
  • Font
  • BitmapFile1, BitMapFile2
  • Colors
  • Highlight
  • Tool Tip
  • HotKey
  • Var
  • X, Y
  • Width, Height
  • Script
    Using this field, the user has three options shown below.
Control Script Options
b) Selecting an Action:
  • Show/Hide
  • Move/Resize
  • Undo/Redo
  • Copy/Paste
  • General
Main Window attributes
  • Main Dialog Screen
  • Script File
Motion Buttons (for Jogging)
To Scale a Screen:
  2. Select mode: Screen Scale
Example Original Screen:
Example Scaled up 60%
Hierarchical Sub Script Files
See this Video Demonstration
Axis DRO Number Formats
Axis DRO number formats may now be specified as the Text Parameter in the Screen Editor. If Text is specified, then it is treated as DRO format of number to be displayed. Include any axis characters if desired. If different formats for Inches and mm are desired specify both separated them with ; // e.g. X:%10.4f;X:%10.3f
