- 1 Introduction
- 8 Main Screen Style
- 10 Control styles
- 11 Control attributes
- 12 Main Window attributes
- 13 Bitmap types, Alpha, and locations
- 14 Motion Buttons (for Jogging)
- 15 Performing an action Immediately within Screen Script
- 16 Scaling an Entire Screen or Portion of a Screen
- 17 Hierarchical Sub Script Files
- Show/Hide Controls
- Change Label/Button Text
- Change Font/Text Size
- Bitmap Buttons and Labels
- JPG, BMP, PNG Bitmaps
- Toggle Bitmap Labels (LEDs)
- Custom User Entry Controls
https://www.youtube.com/watch?v=Pp5DPfn8GLI
Main Screen Style
- Label
- Momentary button
- DualLabel
- Select ID
- Show/Hide
- Move/Resize
- Main Dialog Screen
- Script File
To Scale a Screen:
- Select mode: Screen Scale
Example Original Screen:
Example Scaled up 60%
When creating multiple Screens with sections of Controls that are duplicated among screens, possibly re-positioned on the Screen, it is useful to make use of SubScript files. Selecting one or more Controls and setting a SubScript file name for them will move them to a separate file which will then be referenced from the main file. SubScript files can also reference SubScript files in a hierarchical manner.
See this Video Demonstration
