- 1 Introduction
- 3 Dual Button Types in KMotion CNC Screen Editor
- 4 Instantaneous Feed Rate Display
- 5 Split/Full/Hidden GViewer Display on Main Dialog Face
- 6 Using Resizeable/Floating GViewer Control with Custom Screen
- 7 Main Screen Style
- 8 Maximized Captionless KMotionCNC Screens
- 9 Control styles
- 10 Control attributes
- 11 Main Window attributes
- 12 Bitmap types, Alpha, and locations
- 13 Motion Buttons (for Jogging)
- 14 Performing an action Immediately within Screen Script
- 15 Scaling an Entire Screen or Portion of a Screen
- Show/Hide Controls
- Change Label/Button Text
- Change Font/Text Size
- Bitmap Buttons and Labels
- JPG, BMP, PNG Bitmaps
- Toggle Bitmap Labels (LEDs)
- Custom User Entry Controls
Main Screen Style
- Label
- Momentary button
- DualLabel
- Select ID
- Show/Hide
- Move/Resize
- Main Dialog Screen
- Script File
To Scale a Screen:
- Select mode: Screen Scale
Example Original Screen:
Example Scaled up 60%
