Revision as of 21:47, 23 February 2025 by TK (Talk | contribs)
A number of PC Applications using the KMotion Libraries are available in the Software download.  Visual Studio should be used to modify/compile the applications.  Currently the projects are compatible with VS 2022.   In some cases MFC (Microsoft Foundation Classes) capability needs to be added as a separate download.
Link to the Microsoft Free Visual Studio Community Versions
When debugging Managed code such as an App written in C# .NET it is sometimes helpful to step into or set breakpoints or view variables in the Unmanaged C++ KMotion Libraries to understand exactly what is happening.  Visual Studio allows you to do this but the Project Properties for the App must have the "Enable native code debugging" option enabled.
If Visual Studio skips over Unmanaged code calls and refuses to step into the Unmanaged functions you may have some odd Visual Studio debug options set.  Exit debugging and within Visual Studio use the Debug | Options | Debugging | General and select options as shown below:
Note one disadvantage of having native code debugging enabled is that Visual Studio's powerful Edit and Continue option to make changes on-the-fly is not available.  So when not necessary to debug into Unmanaged code it is may be desirable to disable native code debugging.
Note the App being debugged should be using the Debug Versions of the KMotion Libraries from the Debug folder rather than the Release folder.  The BuildAllLibs.sln in configuration Debug may be used to create the Debug Versions.
Quote:
Set the Debug Configuration's Build output path = bin\Debug1    (This can be anything except a folder named "Debug" or "Release")
KMotionDLL.dll
KMotion_dotNet.dll
KMotion_dotNet_Interop.dll
GCodeInterpreter.dll
KMotionServer.exe
TCC67.exe
