Maximum Amount of Possible Axis
cyprian21
Post by cyprian21 » Tue Aug 27, 2024 12:45 am
If I were to make a custom robot controlled with g-code commands, what would be the maximum amount of axis I'd be able to run using g-code in KMotionCNC in combination with the new Kogna 16-Axis Motion Control Board?
I see in the Trajectory Planner tab there are X,Y,Z,U,V and then A,B,C.
I'd like to able to do more, say 3 axis that translate and 7 axis that rotate; 10 total.
Would look something like this:
G93 G1 X0.000 Y0.000 Z0.000 A0.000 B0.000 C0.000 I0.000 J0.000 K0.000 W0.000 F1800
etc
Is this possible?
Thanks in advance,
Cyprian
Re: Maximum Amount of Possible Axis
Post by TomKerekes » Tue Aug 27, 2024 5:00 pm
Hi Cyprian,
The GCode Interpreter currently supports 8 axes - XYZABCUV. These 8 GCode axes can be mapped to any of the 16 Kogna axes. The mapping can also be re-mapped on-the-fly via an MCode/C Program as long as axis parameters (scaling/acceleration) is similar.
