Hi Alex,
That doesn't look too bad. You didn't zoom in enough or plot Position Error so we could see clearly (or post the raw data so we could).
I assume that is a DAC Servo? What is your resolution? What is your lead screw pitch?
That may be just vibration or lead screw wobble that the servo is correcting.
More D Gain (combined with a 2nd order 1KHz Q1.4 Low Pass filter) may help and also allow higher P and I gains.
Message: 12090 |
Date: 8/9/2015 |
| Subject: Re: noise in output |
Hi Alex,
The main purpose for using the Low pass filter is to reduce spikes in the Output that your Amplifier may not like. For example when using a D Gain of say 100 then each time the encoder suddenly changes by 1 count the output will spike 100 DAC counts for 1 Servo Sample. A low pass filter will smooth this out over a few samples. The low pass filter should use the 3rd filter so that it also applies to any Feed Forward. See:
Unfortunately Servo Tuning is fairly complex and difficult and will vary with each system.
Ben posted a great tuning guide. It is for a SnapAmp configuration but the basic methods are the same. See:
Regarding FeedRate changes. You can define what range will be performed in hardware for instant response. See:
And a Video:
HTH Regards TK
Message: 12091 |
Date: 8/9/2015 |
Tom: Just jumping in with a question / clarification about FRO. Doesn't hardware FRO capability start at test version 4.33l(L)? not at the current release 4.32? I spent a few frustrating hours looking for it in 4.32 about two weeks ago. AZ ------- Original Message ------- From : Tom Kerekes tk@... [DynoMotion][mailto:DynoMotion@yahoogroups.com] Sent : 8/9/2015 2:28:19 PM To : DynoMotion@yahoogroups.com Cc : Subject : RE: Re: [DynoMotion] noise in output
Hi Alex,
And a Video:
HTH Regards TK
Message: 12092 |
Date: 8/9/2015 |
Hi AZ,
Hardware FRO was first added in Version 4.33a.
Regards TK From: "'az@...' az@... [DynoMotion]" <DynoMotion@yahoogroups.com> To: DynoMotion@yahoogroups.com Sent: Sunday, August 9, 2015 1:12 PM Subject: RE: Re: [DynoMotion] noise in output
Hi Alex,
And a Video:
HTH Regards TK
