Hi Dan,
Do you have the motors and power supplies connected, axes configured as
steppers, and are you able to move them using the KMotion Executive program's
Console Screen?
For info on how to connect motors see:
http://www.dynomotion.com/Help/Schematics/Connectors.htm
For info on how to configure the axes for steppers see:
http://www.dynomotion.com/Help/ConfigurationScreen/ConfigurationScreen.htm
For info on how to move a motor from the KMotion Console Screen see:
http://www.dynomotion.com/Help/ConsoleScreen/ConsoleScreen.htm
Try typing a command like "MoveRel0=50.0" (Move Relative axis
0 50 cycles) to see if Motor #1 rotates.
Assuming you are able to move motors with the KMotion Executive, there
are several choices on how to control the boards.
They are:
#1 - Write Microsoft Windows program to issue commands to the board
using either Visual Studio C++ or Visual Basic.
#2 - Write a C program that is loaded (and possibly flashed) into the
KMotion board. This program may run in "stand alone" mode where
a host PC isn't even connected.
#3 - Write a GCode motion program and load it into the KMotion
Executive program and execute it.
It's not clear what your application is, or how you want the system to
be operated, but usually the most flexible technique is #1, especially for using
multiple boards. Basically the program issues the same commands that are
available on the console screen. This does require a means of programming
under MS Windows. DynoMotion provides canned examples for Microsoft
Visual Studio 6.0. If you look into the directory where the KMotion
Software was installed there is a directory called:
<IntstallDirectory>\PC VC Examples
Within that folder there is a project called SimpleConsole. This
is a Simple Windows console application that connects to the board, configures
one axis as a stepper, commands the axis to move, reads status to determine
when the motion is complete, and sends a message that will be displayed on the
KMotion Executive Console Screen if it is running. The entire C++ program
is pasted below. To talk to the other axes (on the same board) it is
basically a matter of duplicating code and changing the axis (sometimes
referred as channel) number. The example assumes that there is only one
board connected to the system and takes advantage of the fact that a single
board in a system can be referred to as board 0. When you connect
multiple boards to a system you should change the board number to the USB
identifier for where the board is connected. For more info on multiple
boards see:
http://www.dynomotion.com/Help/MultipleBoards.htm
I hope this helps. Let us know if you have further questions.
// SimpleConsole.cpp
#include "stdafx.h"
#include "stdlib.h"
#include "..\..\KMotionDll\KMotionDll.h" // KMOtion DLL
Header
CKMotionDLL
KM;
// one instance of the interface class
void MyError();
int main(int argc, char* argv[])
int board=0;
char response[MAX_LINE];
// Setup Axis for a simple stepper
motor
if (KM.WriteLine(board,
"DisableAxis1=0")) MyError(); // Set
board 0, Axis 1 to OFF while changing parameters
"Zero1=0")) MyError();
// Zero position board 0, Axis 1
"StepperAmplitude1=80"))MyError(); // Set nominal Sine wave amplitude
to 80/256 of Motor supply voltage
"Vel1=100")) MyError();
// Set Max Velocity to 100 cycles/sec (4 full steps/sec = 1 cycle)
"Accel1=50")) MyError();
// Set Max Acceleration to 50 cycles/sec2
"Jerk1=2000")) MyError();
// Set Max Jerk to 2000 cycles/sec3
"Lead1=10")) MyError();
// Set Inductance Lead compensation to 10 * dV/dt
"OutputMode1=1")) MyError(); //
Set board 0, Axis 1 to MICROSTEP_MODE (see KMotionDef.h)
"EnableAxisDest1 0")) MyError(); // Zero position board
0, Axis 1
if (KM.WriteLine(board, "Echo
Setup Complete")) MyError(); // Echo a string to console
// move board 0, axis 1, 1000
counts relative
"MoveRel1=100")) MyError();
// loop until complete complete
status = 1
do
if
(KM.WriteLineReadLine(board,"CheckDone1",response))
MyError();
while (response[0] != '1');
Move Complete")) MyError(); // Echo a string to console
return 0;
// Display Error and terminate
void MyError()
printf("Unable to communicate
with KMotion board");
exit(1);
Message: 5658 |
Date: 9/13/2012 |
| Subject: Re: KMotion multiple board programming assistance |
Bengt
if I may intrude,
IF you are running step and direction steppers OR step direction servo drives
check the "step on rising or falling setting"
and/or the pulse length or spacing.
the first will cause 1 missed step at each direction change, giving the results you have
the latter can cause 1 to several steps being executed before a direction change takes place
Carl
--- In DynoMotion@yahoogroups.com, "Dan Zimmermann" <gboghmobile@...> wrote:
> To anyone that can help,
> I am currently setting up an application that will use (2) KMotion
> motor control boards. My current knowledge ends with G-code
> programming and servo motor applications i.e. CNC lathes and Milling
> machines.
> In this application I will be using (8) stepper motors but I will be
> only runnng 1-axis at a time.
> If anyone could offer a programming example that uses multiple
> boards and stepper motors it would be helpful for me to see any
> differences in designating linear movement for a stepper motor.
> I am currently writing a line by line requirement of the sequence
> that I need to program to give myself an outline of the motions
> without the numerical values for each move.
> The following is a list of the equipment that I am using;
> -Toshiba M200 Tablet PC running Windows XP Professional
> -KMotion Software
> -(2) KMotion Motor Control Boards
> #1 Motor- (X-axis)
> Model # 5709L-03, Frame Size-23, 0.9 Step angle,
> http://www.linengineering.com/site/products/5709.html
> #2 Motor- (Y-axis)
> #3 Motor- (Z-axis)
> Hybrid Linear Actuator - Size 17 Captive shaft HSI 43000 Series
> 1.8 degree step angle, .00125 travel per step
> http://www.hsimotors.com/hybrid/Size17-Captive.htm#Draw
> #4 Motor- (A-axis)
> #5 Motor- (B-axis)
> Model # 4018M-05, 1.8 degree step angle
> http://www.linengineering.com/site/products/4018.html
> #6 Motor- (C-axis)
> #7 Motor- (D-axis)
> Model # 211-18-02, 1.8 degree step angle
> http://www.linengineering.com/site/products/211.html
> #8 Motor- (E-axis)
> Thank you in advance for any assistance that you may offer and
> please don't hesitate to ask for additional information that you may
> require.
> Cheers
> Dan
> Dan Zimmermann, President
> GBOGH Research
> gboghmobile@...
Message: 5659 |
Date: 9/13/2012 |
Hi Carl,
Analog servos here
Cheers
Bengt
--- In DynoMotion@yahoogroups.com, "carlcnc" <carlcnc@...> wrote:
> Bengt
> if I may intrude,
> Carl
> > machines.
> > -KMotion Software
> > #1 Motor- (X-axis)
> > #2 Motor- (Y-axis)
> > #3 Motor- (Z-axis)
> > #4 Motor- (A-axis)
> > #5 Motor- (B-axis)
> > #6 Motor- (C-axis)
> > #7 Motor- (D-axis)
> > #8 Motor- (E-axis)
> > require.
> > Cheers
> > Dan
> > GBOGH Research
> > gboghmobile@
Message: 5660 |
Date: 9/13/2012 |
there go all my theories lol
--- In DynoMotion@yahoogroups.com, "bsjoelund" <cnc@...> wrote:
> Hi Carl,
> Analog servos here
> Cheers
> Bengt
> --- In DynoMotion@yahoogroups.com, "carlcnc" <carlcnc@> wrote:
> > Bengt
> > if I may intrude,
> > Carl
> > > machines.
> > > -KMotion Software
> > > #1 Motor- (X-axis)
> > > #2 Motor- (Y-axis)
> > > #3 Motor- (Z-axis)
> > > #4 Motor- (A-axis)
> > > #5 Motor- (B-axis)
> > > #6 Motor- (C-axis)
> > > #7 Motor- (D-axis)
> > > #8 Motor- (E-axis)
> > > require.
> > > Cheers
> > > Dan
> > > GBOGH Research
> > > gboghmobile@
Message: 5738 |
Date: 10/6/2012 |
Dave
my best guess is you have a late version of Mach and they have changed the license file [so I heard] maybe that causes it to
not work with the plug in.
I've built several machines with kflop for guys who insist on running Mach, never had any issue
that said , I would never go back to Mach as Kmotion trajectory is
is WAY better ,
so my advice is to switch to Kmotion
Carl
> machines.
> -KMotion Software
> #1 Motor- (X-axis)
> #2 Motor- (Y-axis)
> #3 Motor- (Z-axis)
> #4 Motor- (A-axis)
> #5 Motor- (B-axis)
> #6 Motor- (C-axis)
> #7 Motor- (D-axis)
> #8 Motor- (E-axis)
> require.
> Cheers
> Dan
> GBOGH Research
> gboghmobile@...
