# load the <span class="skimlinks-unlinked">KanalogInitialPID.mot</span> configuration
# '''Change the Input Channel and Output Channel settings''' to the Encoder and DAC you want that motor to use (ie. #1 and #1)
==Max Output For DACs==
[[File:MaxDAC.png|none|link=]]
==Testing Analog Amplifiers==
