Changes
950 bytes added, 22:13, 25 October 2015
/* Axes Servo Tuning and Trajectory Planner */
<div id="yui_3_16_0_1_1445622719616_3315" class="yiv2818182665class" style="color: #000000; font-size: 13.3333px; font-family: HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif; background-color: transparent; font-style: normal;">The Velocity, Acceleration, and Jerk in the Step Response Screen (KFLOP parameter settings) and the Acceleration and Velocity in the KMotionCNC | Tool Setup | Trajectory Planner | Axis Parameters are both used for different things.  The two sets of parameters are independent.  </div>
<div class="yiv2818182665class" style="color: #000000; font-size: 13.3333px; font-family: HelveticaNeue, Helvetica Neue, Helvetica, Arial, Lucida Grande, sans-serif; background-color: transparent; font-style: normal;"><span class="yiv2818182665class">The</span> KFLOP parameters are used for 3rd order motions.   These include things like:  Jogging, Homing, and GCode Rapids (G0).  The units in KFLOP are in counts or steps.<br /><br /><span id="yui_3_16_0_1_1445622719616_3320" class="yiv2818182665class">The KMotionCNC parameters are used for 2nd order (</span><span id="yui_3_16_0_1_1445622719616_3321" class="yiv2818182665class"><span class="yiv2818182665class">infinite </span>Jerk) coordinated motion paths.  These are GCode G1,G2,G3 continuous paths.  The units are in Inches (or in some cases degrees).<br /><br /></span><span class="yiv2818182665class">Tests</span> to find optimal settings for both types of moves should be made using the Step Response Screen.  The Step Response Screen always performs 3rd order motion but 2nd order motion can be simulated by temporarily setting the Jerk to a huge value (1000X the acceleration value).  In general reducing the Jerk value will result in longer times to perform motions, but often the improved smoothness will permit higher maximum accelerations and velocities to be used resulting in overall shorter motion times.<br /><br /><span class="yiv2818182665class">Make</span> sure when testing the size of move is long enough for full acceleration and velocity are achieved.  As a common mistake is to have Acceleration or Velocity Settings set to too high for your system but when testing a short move there is no indication of a problem.  The plot mode of Velocity Output  vs Time can be helpful to verify full Velocity is being achieved.<span id=".C2.A0" class="mw-headline"> <br /></span></div>
Bureaucrat, administrator
469
edits
