Changes
2,862 bytes added, 18:25, 28 July 2018
fix font
The Opto Inputs and Outputs are fully isolated.<br /><br />
==Initial Setup/Testing for Analog AmplifiersLogical "AND" of Opto Output and Relay Driver==<div style="color: #000000; font-size: 13px; font-family: tahoma, 'new york', times, serif; background-color: transparent; font-style: normal;">There is a starting configuration for KFLOP+Kanalog called KanalogInitialPID.mot in Both the \KMotion\Motors folder.  Load it into an axis channel from Relay Driver and Opto Output need to be active to enable the KMotion Configuration ScreenSolid State Relay (SSR).</div><div style="color: #000000; font-size: 13px; font-family: tahoma, 'new york', times, serif; background-color: transparent; font-style: normal;">The basic first steps are to verify the hardware:</div># check the encoder counts correctly# check that the DACs   Such a circuit can command the Amplifier be used to control motor speed.  Test Console commands like DAC0=200  (with assure a SSR remains off until after KFLOP Boots and SWE Relay Driver output goes active and KFLOP is initialized and the axis disabled)# Enable the Servo using the Step Response ScreenOpto Output is activated.  Zero, Enable
Note positions of the SSR and Opto Output may be reversed if desired.  But because relay driver outputs are internally grounded it must be at the bottom.
[[File:RelayDriverAndOptoInSeries.png|none|link=|329x469px]]
==Initial Setup/Testing for Analog Amplifiers==
There is a starting configuration for KFLOP+Kanalog called KanalogInitialPID.mot in the \KMotion\Motors folder.  Load it into an axis channel from the KMotion Configuration Screen.  The basic first steps are to verify the hardware:
# check the encoder counts correctly as shown on the KMotion Axis Screen Position (a KFLOP Axis must be configured as Encoder Input with the Input Channel0 set to the channel where the encoder is physically connected)
# check that the DACs can command the Amplifier to control motor speed.  Test Console commands like DAC0=200 to Output ~ -1V (with the axis disabled - if any axis is enabled and continuously writing to the DAC any Console Command will be overwritten)
# If steps #1 and #2 above work correctly, enable the Servo using the Step Response Screen.  Zero, Enable.  The motor should then attempt to weakly hold position.
==Configuring DAC and Encoder Channels==
I think our software/documents some what over use the word '''channel''' which can confusion. There are Motor Axis Channels, DAC Output Channels, and Encoder Input Channels which are all different things.   This diagram may help:
[http://www.dynomotion.com/Help/SchematicsKFLOP/KFLOPFunctionalDiagram.htm KFLOP Functional Diagram]<br /><br />Any KFLOP Motor Axis Channel can be configured to make use of any DAC or any Encoder by specifying the Input and Output channels. See:<br /> [http://dynomotion..com/Help/ConfigurationScreen/ConfigurationScreen.htm#Input_Channels Configuration ScreenInput Channels]<br /><br />The <span class="skimlinks-unlinked">KanalogInitialPID.mot</span> configuration file is an example of a Kanalog Axis using DAC #0 and Encoder #0.  If simply loaded into multiple Motor Axis Channels it will configure all the Motor Axis to all use DAC 0 and Encoder 0 as their I/O devices.<br /><br />So for example for the Second Motor:
# select Axis Channel #1
# load the <span class="skimlinks-unlinked">KanalogInitialPID.mot</span> configuration
# '''Change the Input Channel and Output Channel settings''' to the Encoder and DAC you want that motor to use (ie. #1 and #1)<br   ==Max Output For DACs==Note the Maximum Output range for the DACs is +/><br />-2047 DAC Counts.  Attempting to output larger values will cause a wraparound effect and runaway or following error fault.  So set the Max Output to 2047 or less.  [[File:MaxDAC.png|none|link=]]
==Testing Analog Amplifiers==
==Drive Enables - Axis Drift with Servo Disabled - Power up Issues==
Kanalog is designed to be precise and linear but not highly accurate (+/- 1% components are used).  Absolute accuracy on the servo output is not normally a requirement for good servo control.    This is not a problem when the servo is enabled as the servo will command whatever output necessary to hold the desired position.   However whenever the servo is disabled the Drive should also be disabled to avoid any motor drive or drift.
The Drive enable signals can be interfaced to KFLOP.  Any I/O can be used as the Drive enables are handled in software as a User Program (see the watchenable.c example).
However please note that unfortunately the Kanalog Outputs Power up in an initially undetermined state for several seconds until KFLOP boots up.  If this is a problem for your system then another means of keeping the Drives disabled should be used during initial power up.  The Kanalog SWE Relay Output Driver is guaranteed to remain disabled until KFLOP fully boots and all Kanalog Outputs are initialized to the off state.
==Forum Threads on Setup and Tuning==
[http://www.cnczone.com/forums/dynomotion-kflop-kanalog/215344-cnc.html Anilam/ supermax Frankenstein project using Dynomotion Kflop and Kanalog boards]
[https://www.cnczone.com/forums/dynomotion-kflop-kanalog/345690-tree325-retrofit-started-9.html#post2128600 Tree325 Retrofit with KFLOP Kanalog] (Thread includes .AVI Videos of User Tuning his system step-by-step)
Bureaucrat, administrator
469
edits
