Relay Drivers / Grounding
Logical "AND" of Opto Output and Relay Driver
There is a starting configuration for KFLOP+Kanalog called KanalogInitialPID.mot in the \KMotion\Motors folder. Load it into an axis channel from the KMotion Configuration Screen. The basic first steps are to verify the hardware:
KFLOP Functional Diagram
Input Channels
- select Axis Channel #1
Max Output For DACs
Testing Analog Amplifiers
