Programming References
C Curly Brackets { }
X = 1 + 1;
Y = X + 1;
Move(1,100);
{X = 1 + 1; Y = X + 1;
Move(1,100);
if (condition)
X = 2;
Y = X + 1;
if (condition)
X = 2;
Y = X + 1;
C Functions (Subroutines)
void SomeFunction(void)
Global Persist Variables
persist.UserData[xxx]
double d;
return d;
double d=v;
Gather Buffer
for (;;) // loop forever
} // end of forever loop
#define TIME_ON 5.0 //seconds
SetBit(OUTPUT_BIT); //yes
ClearBit(OUTPUT_BIT); //no
Common C Programming Mistakes
A common programming mistake is to forget to add the '()' for a function call. It might not be obvious why this isn't flagged as an error. In some programming languages such as Basic a subroutine with no parameters can be called by coding the name with no parenthesis. In C the name of a function represents the address of the function. Adding the () is required to make a function call to that address.
2+2;
2;
ClearStopImmediately;
is a valid expression. The compiler computes the address of the function ClearStopImmediately and does nothing with it.
Note we are working on a new code Validation tool (using splint.exe) that will analyze code, detect no useful purpose, and provide warnings in these types of cases. Look for it in the next Version 4.35.
