Programming References
C Curly Brackets { }
X = 1 + 1;
Y = X + 1;
Move(1,100);
{X = 1 + 1; Y = X + 1;
Move(1,100);
if (condition)
X = 2;
Y = X + 1;
if (condition)
X = 2;
Y = X + 1;
C Functions (Subroutines)
void SomeFunction(void)
Global Persist Variables
persist.UserData[xxx]
double d;
return d;
double d=v;
Gather Buffer
for (;;) // loop forever
} // end of forever loop
#define TIME_ON 5.0 //seconds
SetBit(OUTPUT_BIT); //yes
ClearBit(OUTPUT_BIT); //no
