At this time this is under development and is provided as a Patch to Test Version 4.33h. The Patch DLL (and source changes), C Program Example, and GCode Example are located here:
http://dynomotion.com/Software/Patch/AddG84RigidTapV433h/
Since each system has differences in how rigid tapping is performed a C Program is used to allow flexibility. A typical difference is how the Spindle is controlled. Open Loop, Closed Loop, with or without Feedback, etc. We expect to eventually develop examples for the more common situations.
The GCode Interpreter is hard coded to always invoke the action for MCode M119 to do Rigid Tapping whenever G84 is encountered. For details see the function convert_cycle_g84() in the Interpreter Source Code.
M119 should be configured to Exec/Wait/Sync your C Program in an available Thread (ie 2). 9 parameters are passed into KFLOP persist Variables before the C Program is invoked starting at the specified Var setting. 50 is recommended but anywhere in the 0-199 range might be used as long as it doesn't conflict with anything else and matches where your C Program expects them to be.
// Var+6 - (int) Units #define CANON_UNITS_INCHES 1 #define CANON_UNITS_MM 2
G20
G0 X1 Y1 Z2
G98 G84 Z-1. R.1 Q.1 F.0625
M30
MCode = -1
Bottom = -1.000000
Retract = 2.000000
Peck = 0.100000
Rate = 0.062500
RPM = 1000.000000
Units = Inches
Axis = 2
AxisRes = 10000.000000
