SPINDLE SERVO SPECS
turbothis
SPINDLE SERVO SPECS
Post by turbothis » Wed Apr 03, 2019 3:44 pm
SO TRYING TO FIGURE OUT SOME SPINDLE SPECS FOR TOP SPEED (RPM)
i got 8192 count servo
servo drives a large pulley at 0.69 ratio
so 11872.46 counts per revolution
i would like to limit lathe spindle to 1500 rpm
so in the C program the Velocity number would be reading just encoder count right? per second or something?
so 1500 rpm is 25 per second
so 25 x 11872.46 is 296811 velocity?
Re: SPINDLE SERVO SPECS
Post by Moray » Wed Apr 03, 2019 3:50 pm
That figure looks good to me, although you want to try and keep as much accuracy as possible and not round the number - 296811.5942028985507246
turbothis
Post by turbothis » Wed Apr 03, 2019 3:58 pm
my calculator just saidxxxxx.59 lol
Post by TomKerekes » Wed Apr 03, 2019 4:29 pm
Hi turbothis,
Normally speed is limited by simply limiting what the Spindle can be commanded to do.
What are you trying to do? Allow a higher speed to be commanded, then detect when the speed is actually too high, then kill it?
turbothis
Post by turbothis » Wed Apr 03, 2019 4:59 pm
yes sorry
i want to limit what the Spindle can be commanded to do
this is the velocity value in the C program yes?
Post by TomKerekes » Wed Apr 03, 2019 5:09 pm
Hi turbothis,
Post your spindle programs you are using.
turbothis
Post by turbothis » Wed Apr 03, 2019 5:18 pm
i have not added in any spindle details as that was step 2 of getting the main program running
i have the Z axis disabled for now too
// Home and set the commutation for a 3 phase brushless motor // that is driven using two DAC Outputs // // Phase rotates until index mark is located and Encoder Zeroed
// Function definitions
void Write3PH_DACs(CHAN *chx, float v, double angle_in_cycles);
float fractionf(double v);
// Main function entry point
                float k=0,A=500;   // set coil current amplitude DAC units
                double p0;
        ch0->InputMode=ENCODER_MODE;
	ch0->OutputMode=NO_OUTPUT_MODE;
	ch0->Vel=5000;
	ch0->Accel=5000000;
	ch0->Jerk=30000000;
	ch0->P=3;
	ch0->I=0;
	ch0->D=20;
	ch0->FFAccel=0;
	ch0->FFVel=0;
	ch0->MaxI=200;
	ch0->MaxErr=1e+006;
	ch0->MaxOutput=2000;
	ch0->DeadBandGain=1;
	ch0->DeadBandRange=0;
	ch0->InputChan0=0;
	ch0->InputChan1=0;
	ch0->OutputChan0=1;
	ch0->OutputChan1=0;
	ch0->MasterAxis=-1;
	ch0->LimitSwitchOptions=0x0;
	ch0->SoftLimitPos=1e+030;
	ch0->SoftLimitNeg=-1e+030;
	ch0->InputGain0=-1;
	ch0->InputGain1=1;
	ch0->InputOffset0=0;
	ch0->InputOffset1=0;
	ch0->OutputGain=1;
	ch0->OutputOffset=0;
	ch0->SlaveGain=1;
	ch0->BacklashAmount=0;
	ch0->BacklashRate=0;
	ch0->invDistPerCycle=0.0004;
	ch0->Lead=0;
	ch0->MaxFollowingError=1000000;
	ch0->StepperAmplitude=20;
	ch0->iir[0].B0=1;
	ch0->iir[0].B1=0;
	ch0->iir[0].B2=0;
	ch0->iir[0].A1=0;
	ch0->iir[0].A2=0;
	ch0->iir[1].B0=1;
	ch0->iir[1].B1=0;
	ch0->iir[1].B2=0;
	ch0->iir[1].A1=0;
	ch0->iir[1].A2=0;
	ch0->iir[2].B0=1;
	ch0->iir[2].B1=0;
	ch0->iir[2].B2=0;
	ch0->iir[2].A1=0;
	ch0->iir[2].A2=0;
        ch1->InputMode=ENCODER_MODE;
	ch1->OutputMode=NO_OUTPUT_MODE;
	ch1->Vel=5000;
	ch1->Accel=5000000;
	ch1->Jerk=30000000;
	ch1->P=4;
	ch1->I=0;
	ch1->D=30;
	ch1->FFAccel=0;
	ch1->FFVel=0;
	ch1->MaxI=200;
	ch1->MaxErr=1e+006;
	ch1->MaxOutput=2000;
	ch1->DeadBandGain=1;
	ch1->DeadBandRange=0;
	ch1->InputChan0=1;
	ch1->InputChan1=1;
	ch1->OutputChan0=2;
	ch1->OutputChan1=3;
	ch1->MasterAxis=-1;
	ch1->LimitSwitchOptions=0x0;
	ch1->SoftLimitPos=1e+030;
	ch1->SoftLimitNeg=-1e+030;
	ch1->InputGain0=-1;
	ch1->InputGain1=1;
	ch1->InputOffset0=0;
	ch1->InputOffset1=0;
	ch1->OutputGain=1;
	ch1->OutputOffset=0;
	ch1->SlaveGain=1;
	ch1->BacklashAmount=0;
	ch1->BacklashRate=0;
	ch1->invDistPerCycle=0.0004;
	ch1->Lead=0;
	ch1->MaxFollowingError=1000000;
	ch1->StepperAmplitude=20;
	ch1->iir[0].B0=1;
	ch1->iir[0].B1=0;
	ch1->iir[0].B2=0;
	ch1->iir[0].A1=0;
	ch1->iir[0].A2=0;
	ch1->iir[1].B0=1;
	ch1->iir[1].B1=0;
	ch1->iir[1].B2=0;
	ch1->iir[1].A1=0;
	ch1->iir[1].A2=0;
	ch1->iir[2].B0=1;
	ch1->iir[2].B1=0;
	ch1->iir[2].B2=0;
	ch1->iir[2].A1=0;
	ch1->iir[2].A2=0;
	ch2->InputMode=ENCODER_MODE;
	ch2->OutputMode=NO_OUTPUT_MODE;
	ch2->Vel=  296811.5942028985507246;
	ch2->Accel=5000000;
	ch2->Jerk= 5000000;
	ch2->P=15;
	ch2->I=0;
	ch2->D=20;
	ch2->FFAccel=0;
	ch2->FFVel=0;
	ch2->MaxI=200;
	ch2->MaxErr=1e+006;
	ch2->MaxOutput=2000;
	ch2->DeadBandGain=1;
	ch2->DeadBandRange=0;
	ch2->InputChan0=2;
	ch2->InputChan1=2;
	ch2->OutputChan0=5;
	ch2->OutputChan1=4;
	ch2->MasterAxis=-1;
	ch2->LimitSwitchOptions=0x0;
	ch2->SoftLimitPos=1e+030;
	ch2->SoftLimitNeg=-1e+030;
	ch2->InputGain0=-1;
	ch2->InputGain1=1;
	ch2->InputOffset0=0;
	ch2->InputOffset1=0;
	ch2->OutputGain=1;
	ch2->OutputOffset=0;
	ch2->SlaveGain=1;
	ch2->BacklashAmount=0;
	ch2->BacklashRate=0;
	ch2->invDistPerCycle=0.0003662109375;
	ch2->Lead=0;
	ch2->StepperAmplitude=20;
	ch2->iir[0].B0=1;
	ch2->iir[0].B1=0;
	ch2->iir[0].B2=0;
	ch2->iir[0].A1=0;
	ch2->iir[0].A2=0;
	ch2->iir[1].B0=1;
	ch2->iir[1].B1=0;
	ch2->iir[1].B2=0;
	ch2->iir[1].A1=0;
	ch2->iir[1].A2=0;
	ch2->iir[2].B0=1;
	ch2->iir[2].B1=0;
	ch2->iir[2].B2=0;
	ch2->iir[2].A1=0;
	ch2->iir[2].A2=0;
                // Use f0 and f1 and f2 to flag when index found for ch0 and ch1 and ch2->
                // Break out when both indexes found (f0=1 and f1=1 and f2=1)
                ch0->Enable=FALSE;
                ch1->Enable=FALSE;
                ch2->Enable=FALSE;
                int f0,f1,f2;		// Index found flags
				f0=0;f1=0;f2=0;		// Set all to index not found
                for (;;)		//Indefinite loop
				if (f0==1 && f1==1 && f2==1) break;		// Done if all indexes found
                   if (f0==0)				// If Ch0 index not found
				                    WaitNextTimeSlice();
                                    Write3PH_DACs(ch0,A, ++k/10000.0);  // move the pole
                                    if (ReadBit(36))  // check for index mark ch0
                                                p0=ch0->Position; // Index found so save position
                                                ch0->Position=0;  // set current position to Zero
                                                ch0->CommutationOffset = 658;  // from auto phase find
                                                printf("Position ch0 = %f\n",p0);
                                                f0=1;		// Mark as ch0 index found
                                    }  // End readbit
                   }  // End if f0=0
                   if (f1==0)				// If Ch1 index not found
                                Write3PH_DACs(ch1,A, ++k/10000.0);  // move the pole
                                if (ReadBit(37))  // check for index mark ch1
                                                p0=ch1->Position; // Index found so save position
                                                ch1->Position=0;  // set current position to Zero
                                                ch1->CommutationOffset = 658;  // from auto phase find
                                                printf("Position ch1 = %f\n",p0);
                                                f1=1;		// Mark as ch1 index found
                                    }  // End readbit
                         }  // End f1=0
                    if (f2==0)				// If Ch2 index not found
                                Write3PH_DACs(ch2,A, ++k/10000.0);  // move the pole
                                if (ReadBit(38))  // check for index mark ch2
                                                p0=ch2->Position; // Index found so save position
                                                ch2->Position=0;  // set current position to Zero
                                                ch2->CommutationOffset = 1920;  // from auto phase find
                                                printf("Position ch2 = %f\n",p0);
                                                f2=1;		// Mark as ch2 index found
                                    }  // End readbit
                         }  // End f2=0
                    }  // End for loop
                EnableAxisDest(0,0.0f);  // Enable servo at destination of 0   X axis
              //  EnableAxisDest(1,0.0f);  // Enable servo at destination of 0   Z axis
                EnableAxisDest(2,0.0f);  // Enable servo at destination of 0   A axis
                DefineCoordSystem(0,-1,-1,2); // define which axes are in use
                // Loop forever outputting Servo output to dual DAC_SERVO_MODE
                for (;;)
                                if (ch0->Enable)  // if axis enabled commutate and output else command zero to DACs
                                                Write3PH_DACs(ch0,ch0->Output, (ch0->Position + ch0->CommutationOffset) * ch0->invDistPerCycle);
                                                Write3PH_DACs(ch0, 0.0,0.0);
                                if (ch1->Enable)  // if axis enabled commutate and output else command zero to DACs
                                                Write3PH_DACs(ch1,ch1->Output, (ch1->Position + ch1->CommutationOffset) * ch1->invDistPerCycle);
                                                Write3PH_DACs(ch1, 0.0,0.0);
                                 if (ch2->Enable)  // if axis enabled commutate and output else command zero to DACs
                                                Write3PH_DACs(ch2,ch2->Output, (ch2->Position + ch2->CommutationOffset) * ch2->invDistPerCycle);
                                                Write3PH_DACs(ch2, 0.0,0.0);
                }  // End for loop
} // End main()
                float theta,sin1f;
                if (angle_in_cycles<0)
                DAC(chx->OutputChan0, (int)(v * Sine3PH(theta,&sin1f)));
                DAC(chx->OutputChan1, (int)(v * sin1f));
               }  // End Write3PH()
Post by TomKerekes » Wed Apr 03, 2019 10:11 pm
Hi turbothis,
You will need to figure out what kind of Spindle you have and how it will be interfaced before we can help you.
You might see this.
turbothis
Post by turbothis » Mon Apr 08, 2019 6:33 pm
well i am running my A axis servo/spindle with the dual DAC outputs
it has 11872.46 counts per rev
so i am thinking this program
#define SPINDLEAXIS 4
#define FACTOR (1187246.0/6000) //   counts per second  =  RPM
// desired speed is passed in variable 1
// save in user variable 99 the last speed setting
// save in user variable 98 whether it was off, CW, or CCW (0,1,-1)
// save in user variable 97 the last desired speed
	float speed = *(float *)&persist.UserData[1];  // value stored is actually a float
	float LastSpeed = *(float *)&persist.UserData[99];  // get last speed setting
	float LastState = persist.UserData[98];  // get last state
	if (LastState==0)
		// if spindle is off and User Changes the speed
		// just save the desired speed
		persist.UserData[97] = persist.UserData[1];
		return 0;
	if (LastSpeed != speed)
		LastSpeed = speed;
		Jog(4,LastSpeed * FACTOR);
	*(float *)&persist.UserData[99] = LastSpeed;
with this being run with dual DAC's does the jog program need to be in the axis enable program?
and i am thinking to just have M5 zero output to the DAC's?
	DAC(4, 0);
	DAC(5, 0);
Post by TomKerekes » Mon Apr 08, 2019 8:04 pm
Hi turbothis,
Since your spindle can be operated as an axis I'd recommend you base your code on the newer \SpindleUsingJogs\SpindleOnCWJogV2.c.
To stop the Spindle (M5) use \SpindleUsingJogs\SpindleOffJogV2.c. This will permit a decelerated and controlled stop. Writing to the DACs wouldn't work as your Dual DAC code would immediately overwrite the DAC with new values as it is writing continuously.
You can then add an if condition to limit the speed value.
