Forward / Reverse buttons
marker
Post by marker » Fri Jan 18, 2019 9:09 am
Hello
On the main KmotionCNC screen there is a button "FEED HOLD".
When you press it, the G code stops running and 2 additional Forward / Reverse buttons appear.
I need to manage these commands from the C program.
To stop / start, I use the command:
if (ReadBit (33)) // Watch an external input switch
StopCoordinatedMotion (); // feedhold
else ResumeCoordinatedMotion (); // resume feedhold
Question: how to manage forward / reverse commands
There is a command to control the steps in the G code:
DoPC (PC_COMM_SINGLE_STEP);
But it works only forward, how to implement the reverse?
Thanks for answers. (Sorry for my English)
Re: Forward / Reverse buttons
Post by TomKerekes » Tue Jan 22, 2019 5:17 pm
Hello marker,
Sorry I somehow missed this.
You can command forward and reverse motion within KFLOP along a path by calling the function:
void SetFROTemp(float FRO); // Temporarily change from current to the specified FRO using a nominal rate, override FeedHold, don't save as LastFRO
With something like SetFROTemp(0.2); or SetFROTemp(-0.2);
Regarding DoPC (PC_COMM_SINGLE_STEP); - there isn't any command for single stepping GCode in reverse. However when reverse feeding the GCode Line number that created the motion should update automatically.
marker
Post by marker » Wed Jan 23, 2019 5:49 am
Thanks for the answer
Works great
