Power up Reset (low true) output
Moderators: dynomotion, TomKerekes, sfzeller
Snyggis
Post by Snyggis » Wed May 16, 2018 12:13 am
I am wondering the purpose for Pin 4 on JP 4? Is this to indicate the state of the KFlop board, or an external way to reboot the board?
It sounds like it could be both "Power up Reset (low true) output". Does this mean if I ground the pin it will reboot? Or does it mean that it is low when the KFlop is on?
SL
Re: Power up Reset (low true) output
Post by TomKerekes » Wed May 16, 2018 12:49 am
Hi SL,
It’s not normally required but you are correct it can be used to reset your electronics or you can GND the pin to force a reset.
