Fourth axis
Fourth axis
Can’t get second kstep to operate fourth axis
Re: Fourth axis
Please put more effort into your question. Describe your system, what you are trying to do, what you have done, and what happens. Post your initialization C program.
Re: Fourth axis
Hooked up kflop and both steppers per dyna motion. Then nothing worked removed the 4wire jumper between ksteps and supplied outside voltage then nothing worked except rotary using x axis button. Hooked up kflop/kstep per original and left Ethernet between second kstep and kflop then x,y,z worked normally but rotary did not
Re: Fourth axis
Did you mean KSteps? Not steppers?Hooked up kflop and both steppers per dyna motion.
It’s Dynomotion by the way.
Put those back. They are needed.Then nothing worked removed the 4wire jumper between ksteps
Its important you tell us how things are configured as we asked. Post your Initialization C program.Hooked up kflop/kstep per original and left Ethernet between second kstep and kflop then x,y,z worked normally but rotary did not
