I have a cnc punch press machine and i want to retrofit the cnc control
I want an experit to tell me what motion control i need and breakout boards ill need with the mach 3
The machine has 4 axies
I want to use ac servo motors
Nisshinbo punch press
Re: Nisshinbo punch press
Do the Servo Drives accept +/-10V analog velocity commands? Do they provide Differential Encoder Position outputs?
If so you could use our KFLOP + Kanalog boards. Will optionally a Konnect if you require more IO.
You could use our Free KMotionCNC software.
