Resurrecting an old project
FlyingScot
Post by FlyingScot » Wed Jan 08, 2020 11:52 pm
Hi Tom
I have decided to complete a part built router I started nearly 10 years ago using kflop & Kanalogue running Parker drives and servo's on kflop v4.22.
Will there be any problems upgrading to the latest firmware?
Arthur
Re: Resurrecting an old project
Post by TomKerekes » Thu Jan 09, 2020 12:33 am
Hi Aurthur,
No
FlyingScot
Post by FlyingScot » Sat Jan 11, 2020 8:18 pm
Hi Tom
Is there any way in finding my old forum posts from September October 2010 so that I can figure out my old settings?
Art
Post by TomKerekes » Sat Jan 11, 2020 9:39 pm
Hi Art,
The old Yahoo Group is archived here.
FlyingScot
Post by FlyingScot » Wed Jan 15, 2020 3:30 pm
I was unable to find the original posts in the forum so this has turned out to be a new setup using windows 10 as the old PC would not come back to life.
The machine is a simplec 3 axis router using parker servo's and drive's. Spindle will just be a relay switching router on and off.
I have managed to get servo's connected, tuned and have generated the C prog. Installed & configured the mach plugin but not sure what to do in Mach ports and pins settings.
I was going to set the router up in mach3 as my lathe and mill are running mach3 but now beginning to wonder if it is worth it.
I use Bobcad to generate my code files. I can't find a Bobcad post processor for Kmotion do you know of one?
Best regards
Arthur
Post by TomKerekes » Wed Jan 15, 2020 7:01 pm
Hi Art,
Since the Plugin and KFLOP generates the motion the Ports and Pins are mostly not used and are set to a dummy Port 0. See Step 6 here.
No I'm not aware of one. Usually the one for Mach3 should be very similar. If you find one please add it to our wiki here.
