REGARDING ROTARY AXIS BACKLASH
AmitKumar171
Contact:
Post by AmitKumar171 » Wed Dec 25, 2019 11:19 am
Hi tom,
I am using kflop for my 5 axis machine.
Which is having 3 linear axis (X, Y, Z) and 2 rotary axis (A, C).
I am facing problem related to backlash, which i want to adjust in my init.c file.
My A axis is having gearbox which is having reduction ratio of 1:39, but also having a backlash of 1 arc-minute (0.016 Degrees).
I want to adjust same backlash in int file eg.
ch0->BacklashAmount=0;
ch0->BacklashRate=0;
the above code i have in my init file. I have seen the manual also which says that backlash will be (BACKLASH_OFF, BACKLASH_LINEAR).
For rotary axis A , how should i adjust because rotary backlash setting option is not there as shown above. ?
Is there any separate option for adjusting rotary axis or gearbox backlash.
Waiting for your kind reply.
Thank You
AMIT KUMAR
Re: REGARDING ROTARY AXIS BACKLASH
Post by TomKerekes » Wed Dec 25, 2019 5:55 pm
Hi Amit,
Configure it the same as a linear axis.
AmitKumar171
Contact:
Post by AmitKumar171 » Thu Dec 26, 2019 8:21 am
Hi tom,
Thanks for the reply.
I will test the same and let you know the results.
I have one more doubts regarding maximum frequirency of pulse generating in kflop.
KFLOP has 8 axes of Step and Direction. Output pulses up to 2.5 MHz can be generated.
In the above line in your manual , does that mean for 2.5MHz for each axis then 8 axis will be 2.5 * 8 = 200 MHz, ? or
2.5MHz is for all 8 axis combining. ?
or what is the maximum speed in usteps/sec pulse that kflop can give combining all 8 axes.
Thank You
AMIT KUMAR
Post by TomKerekes » Thu Dec 26, 2019 9:53 am
Hi Amit,
2.5MHz each axis independently.
