KMotionCNC default units on open
axeman
Post by axeman » Fri Aug 09, 2019 4:17 am
I have recently upgraded to ver435b and noticed KMotionCNC defaults to open in inches.
I work in mm and would like the default to be in mm. How do I set this?
William
Re: KMotionCNC default units on open
Post by Moray » Fri Aug 09, 2019 1:09 pm
You need to either change the settings in the relevant settings file, or use a different settings file.
If you open Tool Setup, then select the Tool/Setup Files tab, the Setup File selection is what controls the default units when KMCNC loads.
You can either switch to a MM version of whatever setup file is being used, or edit your own (the file is pretty self explanatory, with all the alternative options listed)
axeman
Post by axeman » Sat Aug 10, 2019 9:52 am
Thank you.
It has been a while since I needed to access these files and I should have found them. It is good to have your support though, it is appreciated.
All working well!
