need serious help again
turbothis
Re: need serious help again
Post by turbothis » Tue Mar 19, 2019 9:41 pm
ok good progress
i got this C program driving the servo on the bench with great performance
// Home and set the commutation for a 3 phase brushless motor
// that is driven using two DAC Outputs
// Phase rotates until index mark is located and Encoder Zeroed
// Function definitions
void Write3PH_DACs(CHAN *ch0, float v, double angle_in_cycles);
float fractionf(double v);
	float k=0,A=200;   // set coil current amplitude DAC units
	double p0;
	// define the axis as 3 phase BRUSHLESS_3PH_MODE
	ch0->InputMode=ENCODER_MODE;
	ch0->OutputMode=NO_OUTPUT_MODE;
	ch0->Vel=5000;
	ch0->Accel=5000000;
	ch0->Jerk=30000000;
	ch0->P=1;
	ch0->I=0;
	ch0->D=4;
	ch0->FFAccel=0;
	ch0->FFVel=0;
	ch0->MaxI=200;
	ch0->MaxErr=1e+006;
	ch0->MaxOutput=1000;
	ch0->DeadBandGain=1;
	ch0->DeadBandRange=0;
	ch0->InputChan0=0;
	ch0->InputChan1=0;
	ch0->OutputChan0=0;
	ch0->OutputChan1=1;
	ch0->MasterAxis=-1;
	ch0->LimitSwitchOptions=0x0;
	ch0->SoftLimitPos=1e+030;
	ch0->SoftLimitNeg=-1e+030;
	ch0->InputGain0=-1;
	ch0->InputGain1=1;
	ch0->InputOffset0=0;
	ch0->InputOffset1=0;
	ch0->OutputGain=1;
	ch0->OutputOffset=0;
	ch0->SlaveGain=1;
	ch0->BacklashAmount=0;
	ch0->BacklashRate=0;
	ch0->invDistPerCycle=-0.0004;
	ch0->Lead=0;
	ch0->MaxFollowingError=400000000;
	ch0->StepperAmplitude=20;
	ch0->iir[0].B0=1;
	ch0->iir[0].B1=0;
	ch0->iir[0].B2=0;
	ch0->iir[0].A1=0;
	ch0->iir[0].A2=0;
	ch0->iir[1].B0=1;
	ch0->iir[1].B1=0;
	ch0->iir[1].B2=0;
	ch0->iir[1].A1=0;
	ch0->iir[1].A2=0;
	ch0->iir[2].B0=1;
	ch0->iir[2].B1=0;
	ch0->iir[2].B2=0;
	ch0->iir[2].A1=0;
	ch0->iir[2].A2=0;
	ch0->Enable=FALSE;
	for (;;)
		WaitNextTimeSlice();
		Write3PH_DACs(ch0,A, ++k/1000.0);  // move the pole
		if (ReadBit(36))  // check for index mark
			p0=ch0->Position; // save position
			ch0->Position=0;  // set current position to Zero
			ch0->CommutationOffset = 658;  // from auto phase find
			printf("Position = %f\n",p0);
			break;
	EnableAxisDest(0,0.0f);  // Enable servo at destination of 0
	DefineCoordSystem(0,-1,-1,-1); // define which axes are in use
	// Loop forever outputting Servo output to dual DAC_SERVO_MODE
	for (;;)
		CHAN *ch=ch0;
		if (ch->Enable)  // if axis enabled commutate and output else command zero to DACs
			Write3PH_DACs(ch, ch->Output, (ch->Position + ch->CommutationOffset) * ch->invDistPerCycle);
			Write3PH_DACs(ch, 0.0, 0.0);
void Write3PH_DACs(CHAN *ch, float v, double angle_in_cycles)
	float theta,sin1f;
	if (angle_in_cycles<0)
	DAC(ch->OutputChan0, (int)(v * Sine3PH(theta,&sin1f)));
	DAC(ch->OutputChan1, (int)(v * sin1f));
i just did some hand motor tuning in the C program and not in the step/response tab as i could not figure out anything productive in there at all.
the step/response just tests your motor action and then if you like the settings just paste them in the C program right? like i did not skip some step in the middle of this?
turbothis
Post by turbothis » Tue Mar 19, 2019 9:44 pm
TomKerekes wrote:
Tue Mar 19, 2019 9:19 pm
Hi turbothis,
No. To commutate properly all that is required is the encoder counts per cycle. But that is why the report shows the phases going through 4 complete cycles to cause one motor revolution.
so i have some 4 pole servos to use down the road and this would show 2 complete cycles per rev?
turbothis
Post by turbothis » Tue Mar 19, 2019 9:55 pm
i got a small issue with the "step size" feature on the main screen. it does not reflect what i have set in the traj. planner page
in fact when i click the tab to move by the increment it does nothing, on all step settings...
Post by TomKerekes » Tue Mar 19, 2019 10:49 pm
Hi turbothis,
ok good progress
Great :)
You should optimize and verify the motor tuning (of all axes) with the Step Response Screen before trying to run KMotionCNC. If you post the results we can help. See also here.
That is correct. But I highly recommend using the Step Response Screen instead.
correct
It seems the Z axis is disabled. Is it included in the Coordinate System? All axes in the Coordinate System must be enabled to do Step Moves.
Note you also might set the Axis Resolutions of unused axes to a non-zero value such as 1000 counts/inch. Zeroes might cause division by zero issues.
turbothis
Post by turbothis » Tue Mar 19, 2019 11:04 pm
great
i got some work to do on this and i will get back when i have troubles
thanks
