KMotion.exe's Main Window persistance was added back in 2016. You must be using an old Version.My main complaint is when I start it up and that damn white window covers my whole monitor, every time! What is the possible purpose of that? I'm sure I have spent way too many total hours resizing it back to the menu strip, which is all that is needed...
Why kmotionserver?
Re: Why kmotionserver?
Hi geraldft,
You are correct - it did finally change with V434. I haven't migrated yet...
I can't find any documentation on KmotionServer.. I think the concept is to manage communication from to/from multiple PC applications to/from multiple KFLOP boards.. But I have not found how to set it up/ use it.. I'd like to have both KMOTION running for console access and and KMOTIONCNC for machine control..
Hi skeitzer,
Correct, that is the purpose. You don't need to be concerned with KMotionServer as its all transparent to you. Just run KMotion.exe and KMotionCNC.exe at the same time.
PatJefferson
Can I know more about it?rlkeck10 wrote: ↑Wed Apr 29, 2020 1:02 pmIn trying to modify KmotionCNC, it is useful to understand how it works. Unfortunately, there is a LOT of code involved, and it is sometimes obscure and mostly undocumented and uncommented. In looking at it, one of the first questions I came up with is what is the point of KmotionSever.exe? It appears to only add complexity without adding value.
I would really like to redo KmotionCNC using WPF or some other modern GUI framework and get rid of all the MFC stuff (MFC is way past its prime), and to this end it would be nice if the "Driver Model.doc" file or the wiki contained a lot more elaboration on the system architecture.
You can discover many games at android games, diverse genres, ready to bring you diverse and interesting gaming experiences on mobile phones.
