RTCP 5 axis machine
Re: RTCP 5 axis machine
mfc140d.dll is a Debug library. It should only be needed if you run the KMotionCNC.exe in the Debug Directory. Run KMotionCNC.exe from the Release folder. Double click on KMotionCNC.exe in the C:\KMotion435b\KMotion\Release folder.
Thanks for not sleeping at this late hour. But the problem persists with the original file the program works. With a new net.on the screen on the right original file. I don 't have something in my compieter? you need more information and help me?
Hi Igor,
Did you understand my previous post? Did you do it? What happened?
Yes understood, not working...TeamViewer?
Hi Igor,
"Not working" is not a very decriptive answer. What happened?
For a fee we can connect into your system and help you with troubleshooting, training, configuration, programming, and tuning. We don't guarantee any specific result. For this we charge $250/hr with a 2hr minimum. Contact support if you would like to do this.
Двойной щелчок по KMotionCNC.exe в C: папка \ KMotion435b \ KMotion \ Release.- the program works. However, when you add a file to the "release" folder, the program does not work.
1 step - I install KMotion CNC 435b. After running the program I receive such notification
Step 2 - I copy the replacement file- "DSPKFLOP.out - 14.08.2018"
3 step - added "kinematics" file. At simulation and 5 axial trajectory. there is such picture 4 steps - When you add a GCodeInterpreter replacement file, the program does not work. do you understand me?
..Step 2 - I copy the replacement file- "DSPKFLOP.out - 14.08.2018"
Hi Igor,
Step 1 - Good
Step 2 - Wrong. Do not copy any file. Instead use KMotion.exe | Config/Flash Screen | Flash New Version Button
Step 1 - Good
Step 2 - new version, reloaded board, added file (replacement) GCodeInterpreter. the program is not started.In 3 seconds the program closes
The program works, but when you press G Viever, it collapses (closes) where you take the correct DSPKFLOP file. Out ?
Hi Igor,
The file is "GCodeInterpreter.dll" not "GCodeInterpreter."
Please try the following:
- Disconnect KFLOP USB
- Rename C:\KMotion435b -> C:\KMotion435bxxx
- Install KMotion435b
- Delete C:\KMotion435b\KMotion\Release\GCodeInterpreter.dll
- Copy new GCodeInterpreter.dll to C:\KMotion435b\KMotion\Release folder
- Right click C:\KMotion435b\KMotion\Release\GCodeInterpreter.dll | Properties | Unblock
- Windows Security | Virus & threat protection settings | Real-time protection | Off
- Double click C:\KMotion435b\KMotion\Release\KMotionCNC.exe
- report what happens
