RTCP 5 axis machine
Re: RTCP 5 axis machine
Post by TomKerekes » Tue Jan 14, 2020 5:44 pm
Hi Igor,
Here is the file you attached. It is different. Which one are you using?
Igor
Post by Igor » Tue Jan 14, 2020 6:03 pm
The last correct, if you select any configuration file, the blinking does not disappear
Post by TomKerekes » Tue Jan 14, 2020 6:59 pm
Hi Igor,
I don't understand. Why did you send the file with the line still in?
You must re-boot KFLOP after removing the line.
Igor
Post by Igor » Tue Jan 14, 2020 8:51 pm
The last, with the line removed! And the blinking problem persists on any other configuration files! Error should be ignored
Post by TomKerekes » Tue Jan 14, 2020 9:44 pm
Hi Igor,
Please put more effort into your responses. Respond completely to everything, not just one thing. otherwise things take much longer to solve.
Did you re-boot KFLOP after removing the line?
Igor
Post by Igor » Wed Jan 15, 2020 9:25 am
yes. What exactly do you mean by "download"?
Post by TomKerekes » Wed Jan 15, 2020 7:11 pm
Hi Igor,
I don't recall saying "download". Did you mean "re-boot"?
You might Flash "New Version" if you Flashed anything such as KStepPresent=TRUE to remove it. Did you ever Flash anything into KFLOP? We don't recommend ever doing this. To be absolutely sure Flash "New Version" to be sure KFLOP is in a default state.
Igor
Post by Igor » Thu Jan 16, 2020 3:24 pm
Hi Tom thank you the blinking problem is gone. Did I understand correctly that every time you change your programs, you need to update Flash? I have very convenient scripts for mach 3. How do I implement this functionality in Kflop? Search for the center of the procurement, search for the angle, with output for each operator on a separate button. There are ready-made templates? And how to engage them. I worked for many years with mach 3, here decided to try your program, people say that one of the best available solutions.
Center Hole.txt
(3.39 KiB) Downloaded 29 times
Calculation.txt
(527 Bytes) Downloaded 26 times
AVTO Z.txt
(1.18 KiB) Downloaded 29 times
Angle#4.txt
(734 Bytes) Downloaded 26 times
Angle #3.txt
(514 Bytes) Downloaded 27 times
Angle #2.txt
(738 Bytes) Downloaded 28 times
Angle #1.txt
(739 Bytes) Downloaded 29 times
Snap.txt
(1.14 KiB) Downloaded 30 times
Workpiece Centr.txt
(1.44 KiB) Downloaded 27 times
Z=0.txt
(225 Bytes) Downloaded 25 times
Post by TomKerekes » Thu Jan 16, 2020 6:22 pm
Hi Igor,
No. You should never Flash User Programs. Only Flash New Version to keep KFLOP in a virgin default state every power up.
You would need to re-write those into KFLOP C Programs and assign the programs to Buttons in KMotionCNC.
Here is a great example written by Jeremy Brown. He has a link to the code in the comments.
Here is an updated Version (untested)
#define TMP 10					// which spare persist to use to transfer data
#include "..\KflopToKMotionCNCFunctions.c"
// Probe Example to find top, left, bottom of part
void MoveNorth(double distance);
void MoveSouth(double distance);
void MoveWest(double distance);
void MoveEast(double distance);
void MoveUp(double distance);
void MoveDown(double distance);
void MoveXToDest(double destination);
void MoveYToDest(double destination);
void ProbeDown();
void ProbeNorth();
void ProbeSouth();
void ProbeWest();
void ProbeEast();
// Globals
float xRes, yRes, zRes;
#define PROBEBIT 171			// #110
#define PROBESPEED 500.0f		// #111
#define XAXIS 0					// #112
#define YAXIS 1					// #113
#define ZAXIS 2					// #114
#define UPSPEED 2000.0f			// #115
#define DOWNSPEED (PROBESPEED * -1.0f)	// #116
#define WESTSPEED -1000.0f		// #117
#define EASTSPEED 1000.0f		// #118
#define NORTHSPEED 1000.0f		// #119
#define SOUTHSPEED -1000.0f		// #120
#define PLATETHICKNESS 0.621f	// #121
#define SAFEZ 3.0f				// #122
#define PLATEDEPTH 3.0f			// #123
#define PLATEWIDTH 3.0f			// #124
#define BUFFERDISTANCE 0.1f		// #125
#define PROBEDEPTH 0.6f			// #126
#define RIGHTCORNEROFFSET 0.5f	// #127
#define MAXIMUMTOOLDIAMETER 0.5f	// #128
#define LEFTCORNEROFFSET 0.75f	// #129
	printf("\n\nStarting main\n");
	double nTouch, sTouch, wTouch, eTouch;
	double nHole, sHole, wHole, eHole;
	double approxXAxisHoleZero, approxYAxisHoleZero;
	double toolWidth, toolDepth;
	printf("Getting Axis Resolution\n");
	DoPCInt(PC_COMM_GETAXISRES, TMP);
	xRes = *(float *)&persist.UserData[TMP];
	yRes = *(float *)&persist.UserData[TMP+1];
	zRes = *(float *)&persist.UserData[TMP+2];
	printf("Axis Resolutions Found:\n\tx: %f\n\ty: %f\n\tz: %f\n", xRes, yRes, zRes);
	// Find Z Height
	ProbeDown();
	printf("Setting Z DRO to plate thickness: %f\n", PLATETHICKNESS);
	DoPCFloat(PC_COMM_SET_Z, PLATETHICKNESS);
	// Find N side of plate
	MoveUp(BUFFERDISTANCE);
	MoveNorth(PLATEDEPTH - LEFTCORNEROFFSET + BUFFERDISTANCE);
	MoveDown(PROBEDEPTH);
	ProbeSouth();
	printf("Setting nTouch to ch1->Dest: %f\n", chan[YAXIS].Dest);
	nTouch = chan[YAXIS].Dest;
	// Find E side of plate
	MoveNorth(BUFFERDISTANCE);
	MoveUp(PROBEDEPTH);
	MoveSouth(BUFFERDISTANCE + RIGHTCORNEROFFSET);
	MoveEast(PLATEWIDTH - LEFTCORNEROFFSET + BUFFERDISTANCE);
	ProbeWest();
	printf("Setting eTouch to chan[XAXIS].Dest: %f\n", chan[XAXIS].Dest);
	eTouch = chan[XAXIS].Dest;
	// Find W side of plate
	MoveEast(BUFFERDISTANCE);
	MoveUp(PROBEDEPTH);
	MoveWest(BUFFERDISTANCE + PLATEWIDTH + BUFFERDISTANCE + MAXIMUMTOOLDIAMETER);
	ProbeEast();
	printf("Setting wTouch to chan[XAXIS].Dest: %f\n", chan[XAXIS].Dest);
	wTouch = chan[XAXIS].Dest;
	// Calculate Tool Width
	toolWidth = (eTouch - wTouch) / xRes - PLATEWIDTH;
	printf("toolWidth calculated as %f\n", toolWidth);
	// Find S side of plate
	MoveWest(BUFFERDISTANCE);
	MoveUp(PROBEDEPTH);
	MoveEast(BUFFERDISTANCE + PLATEWIDTH - RIGHTCORNEROFFSET + (toolWidth / 2.0));
	MoveSouth(PLATEDEPTH + MAXIMUMTOOLDIAMETER);
	ProbeNorth();
	printf("Setting sTouch to chan[YAXIS].Dest: %f\n", chan[YAXIS].Dest);
	sTouch = chan[YAXIS].Dest;
	toolDepth = (nTouch - sTouch) / yRes - PLATEDEPTH;
	printf("toolDepth calculated as %f\n", toolDepth);
	// Move to Hole Center
	MoveSouth(BUFFERDISTANCE);
	MoveUp(PROBEDEPTH);
	MoveNorth(BUFFERDISTANCE + LEFTCORNEROFFSET + (toolDepth / 2.0));
	MoveWest(PLATEWIDTH - RIGHTCORNEROFFSET - LEFTCORNEROFFSET);
	printf("Setting approxXAxisHoleZero to %f\n", chan[XAXIS].Dest);
	approxXAxisHoleZero = chan[XAXIS].Dest;
	printf("Setting approxYAxisHoleZero to %f\n", chan[YAXIS].Dest);
	approxYAxisHoleZero = chan[YAXIS].Dest;
	// Find Exact Hole Center
	ProbeWest();
	wHole = chan[XAXIS].Dest;
	MoveXToDest(approxXAxisHoleZero);
	ProbeEast();
	eHole = chan[XAXIS].Dest;
	MoveWest(((eHole - wHole) / 2.0) / xRes);
	printf("Setting X DRO to Zero\n");
	DoPCFloat(PC_COMM_SET_X, 0.0f);
	ProbeNorth();
	nHole = chan[YAXIS].Dest;
	MoveYToDest(approxYAxisHoleZero);
	ProbeSouth();
	sHole = chan[YAXIS].Dest;
	MoveNorth(((nHole - sHole) / 2.0) / yRes);
	printf("Setting Y DRO to Zero\n");
	DoPCFloat(PC_COMM_SET_Y, 0.0f);
	MoveUp(SAFEZ);
	printf("Done\n");
	printf("Moving North by %f\n", distance);
	MoveRel(YAXIS, distance * yRes);
	while (!CheckDone(YAXIS));
	printf("Moving South by %f\n", distance);
	MoveRel(YAXIS, -1 * distance * yRes);
	printf("Moving West by %f\n", distance);
	MoveRel(XAXIS, -1 * distance * xRes);
	while (!CheckDone(XAXIS));
	printf("Moving East by %f\n", distance);
	MoveRel(XAXIS, distance * xRes);
	printf("Moving Up by %f\n", distance);
	MoveRel(ZAXIS, distance * zRes);
	while (!CheckDone(ZAXIS));
	printf("Moving Down by %f\n", distance);
	MoveRel(ZAXIS, -1 * distance * zRes);
	printf("Moving XAXIS to %f\n", destination);
	Move(XAXIS, destination);
	printf("Moving YAXIS to %f\n", destination);
	Move(YAXIS, destination);
void ProbeDown()
	printf("Jogging Down at speed:%f\n", DOWNSPEED);
	Jog(ZAXIS, DOWNSPEED);
	printf("Waiting for probe to read high\n");
	while (!ReadBit(PROBEBIT));
	printf("Stopping\n");
	Jog(ZAXIS, 0);
	printf("Waiting for Z motion to stop\n");
void ProbeSouth()
	printf("Jogging South at speed:%f\n", SOUTHSPEED);
	Jog(YAXIS, SOUTHSPEED);
	Jog(YAXIS, 0);
	printf("Waiting for Y motion to stop\n");
void ProbeNorth()
	printf("Jogging North at speed:%f\n", NORTHSPEED);
	Jog(YAXIS, NORTHSPEED);
	Jog(YAXIS, 0);
void ProbeWest()
	printf("Jogging West at speed:%f\n", WESTSPEED);
	Jog(XAXIS, WESTSPEED);
	Jog(XAXIS, 0);
	printf("Waiting for X motion to stop\n");
void ProbeEast()
	printf("Jogging East at speed:%f\n", EASTSPEED);
	Jog(XAXIS, EASTSPEED);
	Jog(XAXIS, 0);
jerbroZCircles_Rev2.c
(6.97 KiB) Downloaded 28 times
