Ethernet stand-alone and Differential axis outputs
DrKnow65
Post by DrKnow65 » Fri Dec 28, 2018 10:57 pm
First post, and as there is no welcome thread, I figured I would toss in a new feature request...
I would like to see an Ethernet based Kflop that could be accessed from miscellaneous PC's on the network. (I.e. PC in the office, PC at the machine in the workshop, wifi tablet for when I want to monitor while on the move, etc).
I am interfacing Panasonic Minas A5 AC servo drives and will be building some ‎SN75ALS191P‎ based dual-output line drivers to convert the LVTTL axis outputs in order to take advantage of the higher speed interface using differential signals provides (4Mpps vs 500Kpps). With the added benefit of noise cancellation to boot :)
Jeff
Re: Ethernet stand-alone and Differential axis outputs
Post by Moray » Sat Dec 29, 2018 9:38 pm
I'll second the ethernet interface request :-)
Regarding the differential outputs, if you're interested, I've got a batch of PCBs for outputting the JP5 step/dir outputs to differential outputs. They have two RJ connectors for input/output, with jumpers to select if signals are passed straight through from the input RJ to output RJ, or diverted to line driver chips, with the differential outputs going to the same pluggable connectors as other Dynomotion boards use.
I made them so I could select if Kanalog encoder inputs 4-7 are used, or the KFlop step/dir channels 4-7 were output to differential outputs.
GS76
Post by GS76 » Tue Jan 29, 2019 5:51 pm
Are there plans for an Ethernet version?
