What is the maximum amount of time I should be spending in the UserCallBack(), beyond which I might expect to see performance issues or unpredictable behavior? What are the recommended types of tasks to be performed in the UserCallBack() and what types of tasks should be avoided within the UserCallBack()?
Thanks in advance,
Griffin Boyle
UserCallBack Timing Constraints
griffinboyle
Re: UserCallBack Timing Constraints
Hi Griffin,
Only a few microseconds.
Every 90us a servo interrupt occurs which services all the Axis Channels and a number of other things. Depending on the number of axes enabled and their configurations the total time will vary with a worst case of around 50us. This leaves the remainder of at least 40us for the System or User Threads to execute as a Time Slice. The User Callback adds to the 90us interrupt time. A User Callback time of 40us would cause Time Slices of 0 time and/or missing interrupts so nothing anywhere near 40us should ever be taken.
You might read this.
There is an example C Program called MeasureIRQ.c which measures the length of its Time Slice and computes the time the interrupt is taking in your configuration.
