we have some problem during axis homing.
It often happens, but only on one axis, that during the dog switch search phase, the axis stops searching before actually finding it and zeros in the wrong place.
I'm worried that it might be due to some noise picked up by the sensor cable.
As a zero function we are using the standard version found in the examples. (HomeIndexFunction.c)
Considering the define "DEBOUNCE_VAL 150", how can I calculate the duration in actual time for the value of 150?
int DoHomeIndexFunction(int axis, // axis number to home
float speed, // speed to move toward home
int dir, // direction to move toward home (+1 or -1)
int Dogbit, // Dog bit number to watch for (use -1 for none)
int Dogpolarity, // Dog polarity to wait for (1 or 0)
float indexspeed, // speed to move while searching for index
int indexbit, // index bit number to watch for (use -1 for none)
int indexpolarity, // index polarity to wait for (1 or 0)
float offset, // amount to move inside limits
float Set_New_Pos) // Set New Position
printf("Dogbit - %d \nDogpolarity - %d\nindexbit %d\nindexbitpola %d\n", Dogbit, Dogpolarity, indexbit, indexpolarity);
printf("ofs - %f \nnewpos - %f\n", offset, Set_New_Pos);
printf("speed - %f \nindex - %f\n", speed, indexspeed);
//return 1;
if (Dogbit != -1) // limit bit specified?
#define DEBOUNCE_VAL 150
int debounce=DEBOUNCE_VAL;
// search for dog
Jog(axis, speed * -dir); // jog slowly in opposite dir
while (1) // loop until Limit bit goes to specified polarity
if(ReadBit(Dogbit) != Dogpolarity)
debounce--;
if(debounce==0)break;
if (!chan[axis].Enable) return 1; // abort/exit if disabled
// release dog
Jog(axis, indexspeed * dir); // jog slowly in opposite dir
if(ReadBit(Dogbit) == Dogpolarity)
debounce--;
Thanks for your suggestion.
Roberto
DoHomeIndexFunction debounce time
Re: DoHomeIndexFunction debounce time
Hi Roberto,
That is a tight loop so will execute based on the speed of the CPU. I timed it at 1.3us /loop. But if the Thread gets pre-empted about 150us will be added each time it gets pre-empted. Below is the code I used to time it.
You might add a WaitNextTimeSlice in the loop to force each loop to be 180us.
Or a WaitUntil to force the loop to execute in a defined time like 3us (unless it gets pre-empted).
Its really best to eliminate the source of the noise.
indexpolarity);
// return 1;
double T0, T1;
#define DEBOUNCE_VAL 20
WaitNextTimeSlice(); // ensure we get a full time slice to begin with
int debounce = DEBOUNCE_VAL;
// search for dog
T0 = Time_sec();
if (ReadBit(Dogbit) != Dogpolarity)
debounce--;
if (debounce == 0)
break;
T1 = Time_sec();
printf("Time = %fus\n", (T1 - T0) * 1e6);
// release dog
if (ReadBit(Dogbit) == Dogpolarity)
debounce--;
if (debounce == 0)
break;
int main()
DoHomeIndexFunction(0, // axis number to home
10000, // speed to move toward home
1, // direction to move toward home (+1 or -1)
0, // Dog bit number to watch for (use -1 for none)
0, // Dog polarity to wait for (1 or 0)
10000, // speed to move while searching for index
1, // index bit number to watch for (use -1 for none)
0, // index polarity to wait for (1 or 0)
1000, // amount to move inside limits
0); // Set New Position
return 0;
roberto.gotti
Thanks a lot for your suggestion.
I agree with you about "eliminate the source of the noise" as best option.
