Spindle orientation - angle movement
cemoa9
Post by cemoa9 » Mon Jun 01, 2020 11:37 am
Hello all,
II just finished retrofit of a Brother 321n with mach3 and a competitor card and am a bit disappointed by the motion planner of mach3.
It seems that Kmotion is much better there with the jerk control, and so I would like to use it for my next retrofit an old Fanuc Robodrill. But there the tool change is a bit tricky, here are the steps :
1) Z axis goes to home position
2) spindle orientates for tool loading / unloading
3) Z axis goes to maximum height and engages umbrella gear
4) spindle rotates a particular angle for each tool pocket, this rotates the umbrella to the desired position
5 ) Z axis goes down by some mm to disengage the umbrella gear
6) spindle orientates for tool loading / unloading
7) Z axis goes down to home position
Spindle would be Step / Dir controlled and the VFD would have a feedback card
Is it something Kflop / Kmotion can perform? I think yes, but I could not find a clear answer, especially on indexing the spindle then performing this accurate angular move.
Cordially
Cemoa9
Re: Spindle orientation - angle movement
Post by TomKerekes » Mon Jun 01, 2020 3:59 pm
Hi Cemoa9,
That should be possible assuming the Spindle can be controlled to move in the required manner.
You would need to write a C Program to perform the sequence you describe.
cemoa9
Post by cemoa9 » Tue Jun 02, 2020 6:42 am
Thank you for your reply, how would you do it?
Send step dir pulses through any output with setbit sleep resetbit sleep setbit... until Z signal is triggered through one input, then again with a specified amount of pulses until good position is achieved ?
Cordially
Francois
Post by TomKerekes » Tue Jun 02, 2020 3:56 pm
Hi Francois,
KFLOP has 8 Step/Dir Generators so it would be simplest to use one. See here. You could then Home and Move the Spindle like any other axis. To use it as a Spindle you would Jog it at the desired speed. You might also read this.
cemoa9
Post by cemoa9 » Tue Jun 02, 2020 4:23 pm
Thank you very much Tom,
Btw, do you know that your name could mean "rounded shape" in Hungarian?
Cordially
Francois
Post by TomKerekes » Tue Jun 02, 2020 4:51 pm
Hi Francois,
I thought it meant "maker of wheels". Very common name similar to "Smith" in the US.
cemoa9
Post by cemoa9 » Tue Jun 02, 2020 5:36 pm
Well now you say it, you are also right, it can also mean maker of wheels.
Anyway, thanks again for you explanations I will purchase the card soon.
Cordially
Francois
