Regarding estop making in for loop
AmitKumar171
Contact:
Post by AmitKumar171 » Mon Dec 30, 2019 1:37 pm
Hi tom,
I am using estop program for disabling all axes.
And if i release the estop all axes are still disabled.
I want to make such that if i release estop, all axes should auto enable. and if i press estop all axis should disable.
I defined bit no 16 as my estop bit.
How to make estop in infinite loop. ? as said above.
Waiting for your kind reply.
Thank You
AMIT KUMAR
Re: Regarding estop making in for loop
Post by TomKerekes » Mon Dec 30, 2019 9:45 pm
Hi Amit,
It may not be a good idea to have the axes automatically enabled when EStop is released, it is up to you to add any and all safety precautions.
But here is some sample code:
#define ESTOP 16
#define XAXIS 0
#define YAXIS 1
// state variables for switch debouncing
int elast=0,elastsolid=-1,ecount=0;
int Debounce(int n, int *cnt, int *last, int *lastsolid);
	int result;
	for (;;) // loop forever
		// Handle ESTOP debounce and detect when changed
		result = Debounce(ReadBit(ESTOP),&ecount,&elast,&elastsolid);
		if  (result == 1)  // pushed?
			DisableAxis(XAXIS);
			DisableAxis(YAXIS);
		else if  (result == 0)  // released?
			EnableAxis(XAXIS);
			EnableAxis(YAXIS);
// Debounce a bit
// return 1 one time when first debounced high
// return 0 one time when first debounced low
// return -1 otherwise
#define DBTIME 300
	int v = -1;
	if (n == *last)  // same as last time?
		if (*cnt == DBTIME-1)
			if (n != *lastsolid)
				v = *lastsolid = n;  // return debounced value
		if (*cnt < DBTIME)	(*cnt)++;
		*cnt = 0;  // reset count
	*last = n;
	return v;
AmitKumar171
Contact:
Post by AmitKumar171 » Thu Jan 02, 2020 5:57 am
Hi tom,
thanks for the reply.
I will test and keep you updated.
Thank You
AMIT KUMAR
