Kogna Ethernet issue when Konnect board is plugged in
Posted: Wed Apr 26, 2023 11:10 am
As you know, I am working on commissioning the new Kogna board.
I seam to have run into another problem that I can't resolve myself.
My testing to date has been with the Kogna board running without any of the expansion boards hooked up.
In all this time, I have not had a single connection / communication issue.
This morning, however, I tried to add a Konnect into the system and I couldn't establish a connection to the board.
Troubleshoot Procedure
(1) Power up Kogna without the Konnect plugged in -> Everything works great
(2) Remove power, tie Konnect into JP4 with ribbon cable & power up Kogna -> the Kogna powers up and LED46/47 flash as they always do during boot-up. However, Kmotion.exe will not connect to the board.
(3) Remove power, remove ribbon cable from JP4, power up Kogna -> board powers up and establishes communication without issue
(4) Repeat steps 2 & 3 above multiple times with repeated behavior
(5) Repeat steps 2 & 3 above with JP6 instead of JP4 - same behavior
(6) Replace Kogna with a Kflop (same Konnect, ribbon cable, power supply etc...) and the Kflop works just fine and I can toggle outputs and read input from Konnect board.
Observations
Without the Konnect in the system the RJ45 LEDs are:
Link: blinking, mostly yellow, sometimes green (note I am colorblind, so my colors might be off)
Activity: solid green
With the Konnect plugged in:
Link: blinking
Activity: off (1 quick flash on when the board is first powered up)
I am using a 5V/ 3 amp power supply connected to JR1
Observations
Link: blinking
