Unexpected behavior on JP5
Posted: Mon Mar 29, 2021 10:02 pm
Hi there,
I recently got a MPG2 – Control Pendant from Automation Technology.
https://www.automationtechnologiesinc.c ... g2-pendant
I have been following the implementation from this post here:
viewtopic.php?f=6&t=1178&p=3139&hilit=mpg#p3139
and linked articles on the Dynomotion Wiki here:
https://www.dynomotion.com/wiki/index.p ... _Interface
I am trying to implement this MPG on JP5.
However, even before hooking up the MPG, I noticed that when Pin 1 is driven high (with 5V+), Pin 2 seems to be producing a 1.4V+ output even though there is a 1K pull down resistor. I have 8 resistors because I am planning to pull down all the JP5 pins eventually, here I am just starting with the first two pins. You can see this on the voltmeter. I am measuring the voltage on Pin 2 while Pin 1 has 5V+ applied.
You can see that in the first picture I am not driving Pin 1 (Pin 2 is reading 0V+) and in the second picture I am driving Pin 1 and strangely Pin 2 is reading 1.4V+.
Any ideas on how I can resolve this?
Thank you,
Cyprian
I am running Kmotion/Kflop Version 4.35e.
Thank you,
Cyprian
