Spray Robot
Re: Spray Robot
Post by TomKerekes » Wed Aug 19, 2020 6:12 pm
Hi Scott,
Very cool! Thanks for sharing. :)
There should be ways to make the motion smoother if necessary. Maybe just less acceleration or Coordinated Motion Low Pass Filtering.
CNC_Machines
Re: Spray Robot
Post by CNC_Machines » Thu Aug 20, 2020 7:43 pm
Thanks Tom! I will check it out, a lot of the jerkyness has to do with the mechanics. The entire assembly is 3D printed. In order to make a solid connection between the plastic pieces and the gearbox shafts, I 3D printed an adapter out of steel with a key slot. It was my first attempt to print metal and there is a lot of slop in the keyway.
I thought it would be nice to wrap up the post with the final code that I wrote..
Two Axis Robot.xlsx
(61.68 KiB) Downloaded 6 times
CoordMotion.cpp
(87.64 KiB) Downloaded 4 times
StdAfx.h
(2.26 KiB) Downloaded 4 times
Kinematics2AxisRobot.h
(982 Bytes) Downloaded 5 times
Kinematics2AxisRobot.cpp
(3.07 KiB) Downloaded 5 times
