Fanuc DC motor drives
Scott Pancheau
Re: Fanuc DC motor drives
Post by Scott Pancheau » Tue Apr 28, 2020 1:45 am
The text documents that the plots downloaded as exceeded the maximum attachment size so I copied the text into word documents. Please let me know if this will not work and how to go about getting the files to you.
Scott
0 Plot with 3 inch move.docx
(516.31 KiB) Downloaded 51 times
0 Axis Plot with about half inch move.docx
(327.49 KiB) Downloaded 43 times
EdinLipka
Post by EdinLipka » Mon May 10, 2021 5:35 pm
Hi....Present day drives don't utilize the tachometer, there are drives out there that should work. I trust Larkin is building up a higher current drive.
You should supplant the tach with encoders. DC engines are the most adaptable out there as they needn't bother with outer compensation.
