For printing runtime other then caption bar of KmotionCNC
AmitKumar171
Contact:
Post by AmitKumar171 » Thu Sep 27, 2018 12:05 pm
Hi all
I am using kflop board.
In Kmotion CNC there is a Run time option in Caption bar of Kmotion cnc here it is shown.
Screenshot (109).png (1.52 KiB) Viewed 1289 times
This run time i wan to print somewhere else using DRO Label on my KmotionCNC screen.
I want to know that how to use a DRO Label for printing Run Time.
Waiting for your kind reply.
Thank You
AMIT KUMAR
Re: For printing runtime other then caption bar of KmotionCNC
Post by TomKerekes » Thu Sep 27, 2018 5:42 pm
Hi Amit,
Here is C Program that monitors whether a Job is Active, Time stamps when a Job Starts, detects when a Job Ends, Formats a Job Time message, and writes it to a DROLabel.
#define TMP 10                    // which spare persist to use to transfer data
void ServiceJobTimer(void);
#define JOBTIMEPERSIST 162
    for (;;)
        ServiceJobTimer();
// Monitor and time Jobs starting and ending
    static BOOL WasActive = FALSE;
    static double StartTime;
    double dt, Seconds;
    int Hours, Minutes;
    char s[80];
    if (JOB_ACTIVE && !WasActive)    // Started ??
        StartTime = Time_sec();
        WasActive = TRUE;
    if (!JOB_ACTIVE && WasActive)    // Ended ??
        WasActive = FALSE;
        dt = Time_sec() - StartTime;
        Hours = (int)(dt / 3600.0);
        Minutes = (int)((dt - Hours * 3600.0) / 60.0);
        Seconds = dt - Hours * 3600.0 - Minutes * 60.0;
        if (Hours > 0)
            sprintf(s, "Last Run Time %d hours %d min %5.1f sec", Hours, Minutes, Seconds);
        else if (Minutes > 0)
            sprintf(s, "Last Run Time %d min %5.1f sec", Minutes, Seconds);
            sprintf(s, "Last Run Time %5.1f sec", Seconds);
        // Put it onto the Screen using Persist
        DROLabel(1000, JOBTIMEPERSIST, s);
Attached is a Screen Script example (also Attached)with the DROLabel that looks like this:
RawCustomWithJobTimeDRO.scr
(45.72 KiB) Downloaded 59 times
ServiceJobTimer.c
(1.3 KiB) Downloaded 64 times
AmitKumar171
Contact:
Post by AmitKumar171 » Mon Oct 01, 2018 6:26 am
Thanks for the reply.
The timer for printing runtime other then caption bar is working fine as expected by the program that you sent.
Will let you know about further updates.
Thank You
AMIT KUMAR
