Importing tooltable in KMotionCNC 4.35a causes a crash of the application
jossmilde
Post by jossmilde » Thu Dec 27, 2018 2:34 pm
When I hover over the tool field in KMotionCNC the application crashes.
I recently updated KMotionCNC from 4.34a to 4.35a.
I copied all settings including my old tool table into C:\KMotion435a\KMotion\Data.
I had a few comments in my tool old tool table, after removing them everything works fine.
I have attached my old and new tool table for reference, maybe someone can find out what's wrong with the old table.
Jos
Re: Importing tooltable in KMotionCNC 4.35a causes a crash of the application
Post by TomKerekes » Thu Dec 27, 2018 8:40 pm
Hi Jos,
Thanks for reporting the bug. The issue has to do with the Tool Tip message being greater than 80 characters. With your comment and offsets the Tool Tip is:
Tool 1 17mm schrobfrees Slot:1 ID:1 Length:30.1660 Diam:17.2500 X offset:-107.1700 Y offset:291.8400
Here is a Patch for Version 4.35a that should solve the problem. Copy it to your KMotion\Release directory.
