I'm finding that when I zero one of my axes, the change is saved to my emc.var file, so my G92 coordinates are wrong the next time I start KMotionCNC. I haven't noticed that behavior in the past. Is there a setting that is causing KMotionCNC to alter the emc.var file?
Is it because I have "Save always" checked in the "Edit fixture offsets" dialog? I've never used that dialog, so I'm not sure how that setting would have changed.
emc.var values changing
Re: emc.var values changing
Hi amowry,
yesIs it because I have "Save always" checked in the "Edit fixture offsets" dialog?
idk. But the default is set true, so if the settings were lost/reset that might be the explanation.I've never used that dialog, so I'm not sure how that setting would have changed.
