Drilling Cycles giving Error in 3+2 Axis operation
I am using KFLOP+KONNECT for CNC machines. I have made code for drilling cycle supported by kmotion (Eg. G80....). And in 3+2 axis it is giving error of plane change and cycle is halted.
Or it is running in horizontal direction, but it should run in vertical direction to make drills.
I am not able to identify the problem, please guide me what am i doing wrong, or in kmotion drilling cycles in 3+2 axes not supported?
Waiting for your kind reply.
Thank You
AMIT KUMAR
AMIT KUMAR
Re: Drilling Cycles giving Error in 3+2 Axis operation
Hi Amit,
Post a small GCode program that gives the error.
What is the exact error message that you are seeing?
It gives error of different plane in drilling cycle.TomKerekes wrote: ↑Fri Sep 03, 2021 3:49 pmHi Amit,
Assume we are drilling in yz plane and with RTCP that plane changes with table rotation.
So it give error of wrong plane with Z move or so.
What could be the error in that case ?
Thank You
AMIT KUMAR
AMIT KUMAR
Hi Amit,
Sorry I don't understand. Please post the exact error message you are getting and the GCode you are running.
Hi tom,
Thank you for earlier reply.
I have attached a drilling cycle G code that runs in 3+2 axis with RTCP on. and instead of moving spindle in actual z direction, it is moving in actual Y direction.
and video of run program also here uploaded in google drive.
https://drive.google.com/file/d/1Jbx7iZ ... sp=sharing
Please help me understand, what am i doing wrong ?
Thank You
AMIT KUMAR
AMIT KUMAR
Hi Amit,
That looks correct to me. With G17 (XY Plane) the G83 drill direction is to be in GCode Z direction. With RTCP on and the part rotated 90 degrees to move the tool tip in Z Axis #1 must change. Same as with a G1 command with that orientation to mill in Z axis #1 would need to change.
Hi tom,
Thanks for your kind reply.
and How can i make it work, to drill whole in that condition, we need actual z direction(#2) to change. But it is changing (#1) as per in the screenshots.
Do i need to change plane in (G18/G19) ?
Waiting for kind reply.
How it is correct, By rotation of part by 90 degrees, still we need to drill whole in actual z direction only right.?That looks correct to me. With G17 (XY Plane) the G83 drill direction is to be in GCode Z direction. With RTCP on and the part rotated 90 degrees to move the tool tip in Z Axis #1 must change. Same as with a G1 command with that orientation to mill in Z axis #1 would need to change
Thank You
AMIT KUMAR
AMIT KUMAR
No, because you rotated the part the drill is now pointing in the Y direction, so you will need to drill in the Y direction.How it is correct, By rotation of part by 90 degrees, still we need to drill whole in actual z direction only right.?
You might try changing the Plane to drill in the Y direction, but it think that might only work on one side as I believe G83 only works drilling negative (down).
In general you may need to code your own drill cycles in GCode with G1/G0 commands in the direction you need.
