Fourth axis
SSN720
Fourth axis
Post by SSN720 » Sat Aug 14, 2021 12:38 pm
Can’t get second kstep to operate fourth axis
Re: Fourth axis
Post by TomKerekes » Sat Aug 14, 2021 12:47 pm
Please put more effort into your question. Describe your system, what you are trying to do, what you have done, and what happens. Post your initialization C program.
SSN720
Re: Fourth axis
Post by SSN720 » Sat Aug 14, 2021 6:21 pm
Hooked up kflop and both steppers per dyna motion. Then nothing worked removed the 4wire jumper between ksteps and supplied outside voltage then nothing worked except rotary using x axis button. Hooked up kflop/kstep per original and left Ethernet between second kstep and kflop then x,y,z worked normally but rotary did not
Re: Fourth axis
Post by TomKerekes » Sat Aug 14, 2021 9:32 pm
Did you mean KSteps? Not steppers?
It’s Dynomotion by the way.
Put those back. They are needed.
Its important you tell us how things are configured as we asked. Post your Initialization C program.
