Rigid tapping
Rigid tapping
I am trying to make the rigid tapping working, I checked the wiki (https://www.dynomotion.com/wiki/index.p ... up_and_Use), set M119 in Execute, wait, and Synchronize (thread 2, variant 50) for the C program from the wiki.
N11 G0 X9.5 Y9.5 Z1
N21 G84 Z-7 R1 F10
But the G84 code is ignored, what did I do wrong?
Cordially
Francois
N11 G0 X9.5 Y9.5 Z1
N21 G84 Z-7 R1 F10
Cordially
Francois
Re: Rigid tapping
Hi Francois,
What is printed on the KMotion.exe Console Screen?
Which program from the wiki? Please post it. Also post your Initialization C Program.
Re: Rigid tapping
Re: Rigid tapping
Init.c says Spindle Axis is 4 but tapping.c has:
#define SPINDLE_AXIS 3 // Spindle Axis With Encoder Feedback
That Tapping.c program is for an open loop Spindle controlled by a DAC and direction bits. Yours appears to be a closed loop axis where it can be controlled with Axis Move commands. So you might use the attached example.
- RigidTapMultiPassJogM119_v1.c
- (3.25 KiB) Downloaded 52 times
Re: Rigid tapping
OoooOOpps, sorry:
Units = mm
Bottom = -7.000000
Pitch = 0.100000
Max Tap Speed Exceeded
Units = mm
Bottom = -7.000000
Pitch = 10.000000
Units = mm
Bottom = -7.000000
Pitch = 10.000000
Units = mm
Bottom = -7.000000
Pitch = 10.000000
Jogging Spindle Stop
Units = mm
Bottom = -7.000000
Pitch = 0.100000
Units = mm
Bottom = -7.000000
Pitch = 10.000000
Units = mm
Bottom = -7.000000
Pitch = 10.000000
Units = mm
Bottom = -7.000000
Pitch = 10.000000
Re: Rigid tapping
Ok done, there is some improvement, but not yet working, I made a video of the result (sorry for the mess and the noise). You can find it here :
https://drive.google.com/file/d/1h1ZtYH ... sp=sharing
Dunno if it matters, but spindle is true in closed loop, but with very low PID values, necessary for the tool change operation.
Cordially
Francois
Cordially
Francois
Re: Rigid tapping
Hi Francois,
The video is not useful. Please explain what you are expecting. Post the GCode (not a photo). Also your C programs and what is printed on the Console Screen.
Re: Rigid tapping
Code :
N1 G54
N11 G0 X9.5 Y9.5 Z1
N21 G84 Z-70 R0.1 F1
N31 G0 X-9.5 Y9.5 Z1
N41 G84 Z-7 R1 F10
N51 G0 X-9.5 Y-9.5 Z1
N61 G84 Z-7 R1 F10
N71 G0 X9.5 Y-9.5 Z1
N81 G84 Z-7 R1 F10
N91 G0 Z50
N101 M30
Console screen:
Units = mm
Bottom = -70.000000
Pitch = 1.000000
Units = mm
Bottom = -7.000000
Pitch = 10.000000
Units = mm
Bottom = -7.000000
Pitch = 10.000000
Units = mm
Bottom = -7.000000
Pitch = 10.000000
Description:
The machine is moving to the coordinates in G0 properly, then stops and goes down a little bit (between 0.1 and 2mm) but the spindle does not rotate. Then moves up to Z1 and reproduces the same movement for the 4 threads.
Expectations:
Well I expect the machine to go to every position and perform a rigid tapping to the given depth pitch and speed.
C program:
Unchanged from the previous posts.
Cordially
Francois
Code :
N1 G54
N11 G0 X9.5 Y9.5 Z1
N41 G84 Z-7 R1 F10
N61 G84 Z-7 R1 F10
N81 G84 Z-7 R1 F10
N91 G0 Z50
N101 M30
Console screen:
Units = mm
Bottom = -70.000000
Pitch = 1.000000
Units = mm
Bottom = -7.000000
Pitch = 10.000000
Units = mm
Bottom = -7.000000
Pitch = 10.000000
Units = mm
Bottom = -7.000000
Pitch = 10.000000
Description:
Expectations:
C program:
Cordially
Francois
Re: Rigid tapping
Please help I really need to put that machine in production and threading is a must
Francois
Francois
