I'm just looking to have this confirmed, but if a C Program triggers more than one MsgBoxNoWait, would it result in only one of them being shown?
The reason I ask, is I was using my mill last night, and had an issue initialising the Tool Changer with a generic failure message I'd coded. I eventually traced the issue to a slot sensor not being aligned, which should have triggered an error specific MsgBoxNoWait, but only the later generic MsgBoxNoWait was shown.
I'm guessing the later one overwrote the first one, as there would only be a few lines of code between them getting triggered?
Multiple MsgBoxNoWait
Re: Multiple MsgBoxNoWait
Hi Moray,
Yes you are correct MsgBoxNoWait is completely non-blocking. It doesn't wait in any case either for a previous command to be completed or for the new message to be acknowledged.
Here is an example of a non-blocking state-machine approach to wait for an acknowledge. Note the printf and Delay are only for demonstration and should be removed when in use.
#define IDLE 0
#define WAITING_RESPONSE 1
int MessageState=IDLE;
int Response;
MsgBoxNoWait("ESTOP!! E-stop activated, or Axis drive in error",MB_OK|MB_ICONEXCLAMATION);
MessageState=WAITING_RESPONSE;
for (;;)
if (MessageState==WAITING_RESPONSE)
printf("Here\n");
Delay_sec(1);
if (MsgBoxGetResponse(&Response)==0) //Communication successful?
// yes, show response
printf("Message Response was %d\n", Response);
MessageState=IDLE;
Thanks Tom, that's what I guessed.
This is part of my tool changer initialisation code, so there are a few prompts to get information, then various messages if something specific fails, followed by a generic failed message, and it's mostly done with non-blocking message boxes and state machines where needed.
The code is below for reference.
If I get time, I'll fix it, but I've added some printfs, so I'll at least get the real problem via the console for now.
#include "Triac.h"
#define IDLE 0
enum {TC_START, TC_CHKCRSLFLAT, TC_CHKDRBR, TC_CHKCRSLOUTUP, TC_CRSLPOSVALID, TC_TOOLVALID, TC_GETTOOLID, TC_CHKSTATE, TC_GETCRSLPOS, TC_GETPOS, TC_INDEX, TC_FAILED, TC_COMPLETE};
int TCStatus = TC_START;
float inputResult;
float awaitingResult = IDLE;
int Response = FALSE;
int Answer;
int *ChangerState = &persist.UserData[TOOL_STATE_VAR];
int *Tool = &persist.UserData[TOOL_VAR];
int *LastTool = &persist.UserData[LAST_TOOL_VAR];
int *CrslPos = &persist.UserData[CRSL_POS];
void tc_init(void)
switch(TCStatus)
case TC_START:
printf("TC_START\n");
// is TCINIT TRUE?
// If it is, then tool changer has already been initialised at some point, and nothing should of caused it now not to be,
// so we ask the operator if they really want to re-run init.
if(ReadBit(TCINITOK)){
if(awaitingResult == IDLE){
char MyMessage[80]; // String to be created and displayed
double CrslP = *CrslPos/4.0;
sprintf(MyMessage,"Tool Changer already initialized, with tool %d in spindle\n Carousel at position %.1f\n Are you sure you want to run Tool Changer Intialisation?",*Tool,CrslP); // build the message we want to show
MsgBoxNoWait(MyMessage,MB_YESNO);
awaitingResult = WAITING_RESPONSE;
printf("awaitingResult WAITING\n");
} else {
printf("Response Succesful\n");
if(Response == IDYES){ // if yes, we want to re-run init
printf("Yes\n");
ClearBit(TCINITOK); // unset that we're initialised
TCStatus = TC_CHKCRSLFLAT; // move onto first step of initialisation
} else if (Response == IDNO){ // else we don't want to re-run init
printf("No\n");
TCStatus = TC_COMPLETE; // move onto the final state
} else {
printf("Invalid response\n"); // we shouldn't get here, but if we do, die!
ThreadDone();
printf("awaitingResult IDLE\n");
} else {
break;
case TC_CHKCRSLFLAT: // Is carousel geneva mechanism on position, or transitioning?
printf("TC_CHKCRSLFLAT\n");
if(ReadBit(CRSLIDX)){ // if bit is high, then we're not on the flat, so quit and tell user to use TC Recovery
MsgBoxNoWait("Carousel not at index. Use TC Recovery",MB_OK|MB_ICONEXCLAMATION);
TCStatus = TC_FAILED;
} else {
TCStatus = TC_CHKDRBR;
break;
case TC_CHKDRBR: // Is carousel geneva mechanism on position, or transitioning?
printf("TC_CHKDRBR\n");
if(ReadBit(DRBR)){ // if bit is high, then drawbar is active (released) so quit and tell user to use TC Recovery
MsgBoxNoWait("Drawbar Released. Use TC Recovery",MB_OK|MB_ICONEXCLAMATION);
} else {
TCStatus = TC_CHKCRSLOUTUP;
break;
case TC_CHKCRSLOUTUP: // Is carousel out/up?
if(ReadBit(CRSLINR) || ReadBit(CRSLDWNR)){ // if in or down relays active, quit and tell user to use TC Recovery
MsgBoxNoWait("Carousel In and/or Down commanded. Use TC Recovery",MB_OK|MB_ICONEXCLAMATION);
} else if((!(ReadBit(CRSLOUT) && ReadBit(CRSLUP))) || awaitingResult == WAITING_RESPONSE) { // if we're still not out/up, or we've already prompted user
MsgBoxNoWait("Carousel not Out and Up.\n Is air supply connected?\nPress OK after connecting air, or cancel to quit and use TC Recovery",MB_OK|MB_ICONEXCLAMATION);
} else {
if(Response==IDOK){ // if OK, then we need to retrigger check, so we simply do nothing, and it'll get rechecked when
printf("OK\n");
} else { // else we want to quit TC Initialisation
printf("Cancel\n");
TCStatus = TC_FAILED; // so set flag to Failed
} else { // else carousle is out and up, so move on
TCStatus = TC_CRSLPOSVALID;
printf("TC_CHCKCRSLOUTUP complete. Moving to TC_CRSLPOSVALID\n");
break;
case TC_CRSLPOSVALID:
if((*CrslPos >= 1) && (*CrslPos<=24) && ((*CrslPos % 2) == 0 )){ // is carousel position is between 1 and 24, and it's equally divisable by 2, it's valid but maybe not correct
printf("CrslPos = %d\n", *CrslPos);
printf("CrslP = %.1f\n", CrslP);
sprintf(MyMessage,"Is carousel at position %.1f",CrslP); // build the message we want to show
MsgBoxNoWait(MyMessage,MB_YESNO|MB_ICONEXCLAMATION);
} else {
printf("Carousel position valid?\n");
if(Response == IDYES){ // if Yes, then move onto Tool checks
printf("Yes\n");
printf("TC_CRSLPOSVALID complete, moving to TC_TOOLVALID\n");
TCStatus = TC_TOOLVALID;
} else if(Response == IDNO) { // else we need to prompt user for position
printf("No\n");
printf("TC_CRSLPOSVALID failed, moving to TC_GETCRSLPOS\n");
TCStatus = TC_GETCRSLPOS;
} else {
ThreadDone();
} else {
printf("CrslPos not valid, move to TC_GETCRSLPOS\n");
break;
case TC_GETCRSLPOS:
//printf("TC_GETCRSLPOS - ask operator for carousel position\n");
Answer = InputBox("Enter Carousel position (use 0.5 for mid positions)",&inputResult);
if (Answer){
} else {
printf("Operator Entered Value of %.3f\n",inputResult);
int CrslP = inputResult * 4;
if((CrslP % 2) != 0) {
printf("Invalid value entered");
// display message box
if(CrslP == 26) // if user entered 6.5, we change it to 0.5
CrslP = 2;
*CrslPos = CrslP;
printf("Carousel position=%d",*CrslPos);
TCStatus = TC_CRSLPOSVALID; // we'll go back a step to confirm position with operator
break;
case TC_TOOLVALID:
if((*LastTool >= 1) && (*LastTool<=99)){ // is Lsst tool from 1 to 99?
if(*LastTool != 99) { // is tool less than 99 (99 indicates no tool in spindle)
sprintf(MyMessage,"Is Tool %d in spindle?",*LastTool); // build the message we want to show
} else {
sprintf(MyMessage,"Is spindle empty?"); // build the message we want to show
} else {
printf("Tool valid?\n");
if(Response == IDYES){ // if Yes, then move onto final completetion
printf("Yes\n");
} else if(Response == IDNO){ // else we need to prompt user for tool
printf("No\n");
TCStatus = TC_GETTOOLID;
} else {
ThreadDone();
} else {
printf("LastTool not valid, move to TC_GETTOOLID\n");
break;
case TC_GETTOOLID:
printf("TC_GETTOOLID - ask operator for current tool\n");
Answer = InputBox("Enter current slot tool is stored\n or 99 if no tool in spindle",&inputResult);
if (Answer){
} else {
*LastTool = (int)inputResult;
printf("Tool position=%d",*LastTool);
TCStatus = TC_TOOLVALID; // we'll go back a step to confirm position with operator
break;
case TC_FAILED:
printf("TC_FAILED - TC either failed or cancelled\n");
MsgBoxNoWait("Tool change initialidation failed. Please Re-try",MB_OK);
ThreadDone();
break;
case TC_COMPLETE:
printf("TC_COMPLETE:Changer Intialised\n");
*Tool = *LastTool;
*ChangerState = T_IDLE;
SetBit(TCINITOK);
sprintf(MyMessage,"Tool Changer initialisation complete.\n Tool %d in spindle\n Carousel at position %.1f\n(If incorrect, rerun initialisation)",*Tool,CrslP); // build the message we want to show
MsgBoxNoWait(MyMessage,MB_OK);
ThreadDone(); // set TC as intialised and quit
break;
printf("TCinit launched\n");
//printf("awaitingResult=%d\n",awaitingResult);
for(;;) // loop forever
// we continually monitor for Z axis being homed, and exit thread with warning message if it's not homed
// (should an Estop occur, Z gets flagged as being unhomed, so we don't need to monitor anything else)
if(!ReadBit(ZHOMED))
MsgBox("Z axis not homed.\nHome Z axis before initialising Tool Changer",MB_OK);
ThreadDone();
tc_init();
Hi Moray,
Yes I see code such as below that does a MsgBoxNoWait then transitions to state TC_FAILED which immediately does a MsgBoxNoWait.
Maybe make a new state that waits for the Message response and then transitions to TC_FAILED ?
} else {
I'll probably take the easy option, and just change it to a blocking message box, as nothing should be moving during this program.
