i got no G viewer
Re: i got no G viewer
Post by TomKerekes » Tue Jan 16, 2024 10:40 pm
am i needing to put your .exe in that?
no
You need to use the Screen Editor on your Screen.
Use Show Hidden so you can see the GViewer Control.
Select the GViewer Control
Change the Var Parameter from -1 to 0
Click Set
Save the Screen File
Restart KMotionCNC to re-load the Screen
also i noticed my program is backwards
I think you want the Option | Tool Setup | Trajectory Planner | Lathe Option | X Positive Front
turbothis
Post by turbothis » Thu Jan 18, 2024 10:57 pm
great instructions!
1 screen viewer made no difference.
2 the "X positive front" button has no change too.
i re-downloaded the newest version and input my data folder for settings to try that
just odd things those two
even with the "simple 2 axis lathe" screen the X positive front makes no change
Post by TomKerekes » Thu Jan 18, 2024 11:40 pm
Please post the Screen file with the change.
You don't see the X axis reversed as shown here? Note you must Show Front View XZ for the GViewer to update. Note also you must select a Tool Image with the appropriate orientation.
turbothis
Post by turbothis » Fri Jan 19, 2024 4:41 pm
sorry i should have posted it after the change
ill look into the tool
TTurboLathe.scr
(61.44 KiB) Downloaded 252 times
Post by TomKerekes » Fri Jan 19, 2024 8:24 pm
The IDC_viewctrl Var is still set to -1 not 0
turbothis
Post by turbothis » Fri Jan 19, 2024 10:27 pm
man, what is going on. lol
mine shows it is 0
thats what it says when i open it up and no joy
TTurboLathe.scr
(61.45 KiB) Downloaded 288 times
Post by TomKerekes » Fri Jan 19, 2024 11:47 pm
This file has it 0. The previous has -1. What changed? Which file is KMotionCNC selected to use?
turbothis
Post by turbothis » Sat Jan 20, 2024 12:29 am
i am using the last one in the picture i posted. still no cut path shown
