Softlimits and scara kinematics
Re: Softlimits and scara kinematics
Post by TomKerekes » Fri Sep 23, 2022 6:05 pm
Hi Ibzan,
That looks reasonable to me.
Please use our later Test Version 4.35h
Do you know how to set breakpoints and debug in VS? If so, I'd set a breakpoint in your equations and see if they are actually being executed. Then set the Actuators in KMotion to some simple case (ie Theta1 = 0 degrees and Theta2 = 90 degrees) and see if the transformation to CAD XY is working. If not, step through the equations to see what is wrong.
Ibzan
Post by Ibzan » Sat Sep 24, 2022 7:59 am
Hi Ibzan,
I already downloaded the KMotion 435h trial version, but I can no longer compile it in VS2019 or VS2022, I tried to search for the 2015 version but I couldn't download it anywhere. When I compile it, it sends me these errors. (Attached photos).
I don't know if I'm compiling it correctly. :roll: :?:
An apology if my doubts are very basic, and thank you very much for taking the time to answer.
Captura de pantalla 2022-09-24 023822.png (8.08 KiB) Viewed 541 times
Post by TomKerekes » Sat Sep 24, 2022 6:13 pm
Hi Ibzan,
You should be able to install VS2015 from the Microsoft Archives. I believe VS2015 Update 3 is the best Version. Note the installation option files have been removed from Microsofts on-line server so the Installation must be copied to your file system and installed from there. See here.
You should also be able to use VS2022 as described here.
Ibzan
Post by Ibzan » Sun Sep 25, 2022 7:46 am
Hello, Tom.
Hi Ibzan,
Hello, Tom.
Thank you very much for the help.
I already solved the compilation, with the steps that you indicate and I was able to use a different kinematics, but it does strange things to me.
Now I'm trying to debug the code to see what I'm doing wrong. :( :( :cry: :cry:
Ibzan
Post by Ibzan » Sun Sep 25, 2022 8:25 am
Hi Ibzan,
The truth is I don't know much about programming, I've used debugging in simple applications but not in these cases.
Steps 1 and 2 of the instructions that I mention cause me confusion. Where do I find KmotionCNC? It mentions that it has to be created, with what extension it has to be generated and how I link it with the new kinematics class, in order to do the debugging. :shock: :shock: :? :?
Very thankful
1)Build KMotionCNC in Visual Studio in Debug configuration (Build Solution)
2)Set KMotionCNC as Startup Project (right-click on project if not already)
3)Debug | Start Debugging
4)File Open your Kinematics2AxisRobot.cpp
5)Set a breakpoint on first executable line in TransformCADtoActuators() (many ways to do this - a click in the margin is easiest)
6)The breakpoint should be hit immediately, the program halts, and a yellow arrow is shown over the red breakpoint dot)
7)hovering over variables should show the value
8)select variables and right-click | add watch to display in a watch window.
9)add variables x and y to a watch window so they can be altered
10)using the watch window change the x y values to something you know the answer to like in your previous posts
11)single step through the code checking the math as you go
note you can go back to a previous line right-clicking | set next statement
Post by TomKerekes » Sun Sep 25, 2022 6:33 pm
Hi Ibzan,
Your code is part of the GCodeInterpeter Library. You can tell Visual Studio to run KMotionCNC which uses this Library by setting this:
Then Debug | Start new instance GCodeInterpreter.
Ibzan
Post by Ibzan » Thu Sep 29, 2022 8:52 am
Hi Ibzan,
Thank you very much, Tom. Your help helped me a lot.
I have already reviewed my equations, and I already have them correct, but now a new problem, arose with the debugger the system works fine, however I compile it again and I want to openthe normal and program it doesn't work correctly.
Am I skipping an important step? :?: :?: :?: :?: :?:
DEBUG
COMPILE
CLOSE VS
Post by TomKerekes » Thu Sep 29, 2022 4:35 pm
Sorry I don't understand the problem or what you are doing.
Are you trying to run KMotionCNC outside of Visual Studio? From the Debug or Release folder?
Ibzan
Post by Ibzan » Thu Sep 29, 2022 6:02 pm
From Visual Studio, when i run it from visual studio KMotionCNC runs fine.For example, I am generating a circle in G code, if I execute it the Planar Robot moves properly and in the G code viewer the figure is correct (figure 1).
If I run it normally, that is to say from the desktop, the robot moves incorrectly and the figure it shows me in G code is incorrect (figure 2 y 3).
After debugging it, I give it complilar. I don't know if I'm missing an important step to update my code?
Thanks again for the help, I hope you understand my doubt or my problem.
Figure 1
figure 2
figure 3
Post by TomKerekes » Thu Sep 29, 2022 6:28 pm
Visual Studio has various build configurations. Basically Debug and Release. Debug is less optimized and easier to Debug. Release is more optimized but difficult to debug. Debug code is placed in the \KMotion\Debug folder. Release code is placed in the \KMotion\Release folder.
Your desktop icon probably points to the Release folder. If so rebuild in the Release Configuration to recompile the Release code.
